Saloon door lockset
DavidDW
Saloon door lockset
Post by DavidDW »
Hi Guys,
I am in the process of installing a new set of saloon doors on my boat and I was wondering if anybody has any advice as to what lockset I should go with?
I know I know, not as interesting as some topics, but security is a big deal!
Thanks for your help.
Re: Saloon door lockset
David,
The best available, that I could find for Hancock's B31, and absolute security was the Mobella McCoy Star MA-02-331-01-100 available through Southco.
Also see the Brochure pdf
The key is cut into a high security blank, available only through Southco/Mobella. Order a duplicate set with the lockset and store them away.
DavidDW
Post by DavidDW »
Thanks Capt. Patrick - not easy when you come down to these small finish off pieces. Who would have thought I would stuggle to work out a lockset!
The Devil's in the details...
Keith Poe
Post by Keith Poe »
I have hung thousands of doors not marine residential and commercial and some industrial.
What kind of material is the door made of ?
I ask because when you mortise out the end of the door it can make them weak.
Keith,
The door was made by epoxy laminating two pieces of 1/2" plywood face to face, then epoxy laminating heavy Formica for the facings and edges. The lockset required a slightly over 1/2" mortise for the thickness of the lock body. Any weakness caused by the mortise is compensated for buy the fully assembled lockset.
Keith Poe
Post by Keith Poe »
Nice installation captain should be plenty strong enough for the application with the marine ply.
I've laminated a few jobs maybe 100 sheets, i once did 20 dental office cabinets in a building laying out sheets and glued them from one end to the other on the second floor hallways so much fumes thought we were going to blow up sky high.
Guy working with me went straight for the room with some kind of gold finishing spinning machine and opened up the cabinet to laminate and rolled up a nice ball of gold from the spin off.
I missed that one dammit lol
my other east
Post by my other east »
Capt Pat, is that epoxy or just gloss paint over the laminate on the exterior of the door?
If so, what did you use to make it adhere the the formica?
Eric
Eric Vincent
1974 31 FBC hull # 315-1442
Eric,
Formica is easily painted using standard paint preperation. The surface was sanded well, first with 80 grit then with 120 grit, then primed with 2 applications of Awlgrip 545 epoxy primer. Sanded again with 240 grit, then topcoated, in this case with Awlgrip 2000. All surfaces were cleaned with Awlprep before spraying.
my other east
Thanks Capt.
Eric Vincent
Users browsing this forum: Google [Bot] and 8 guests
