Capt. Pat, what is the material to use in replacing the stern cockpit panel?
I measure 1/4" thickness. Thanks
Cockpit panel material
side panels
alot of people use pvc foam board.i used 1/4'' underlayment.rolled at least 5 coats of thinned west on both side and ends totally sautrated it . then sanded smooth..primed and painted. the old one were 30 years old figured that was good for me ...
phil
phil
Panel Material
I'm having a friend make panels out of fiberglass. I'll take the 48x60 piece and cut to size. Thickness can be 3/16 to 1/4". I hope to put them in tomorrow, should be 60 deg. in my area.
Rear bulkhead
I had a friend from Hatteras make mine. We usedd 1/4 Strata board and covered both sides with Wilson Art Formica. They were light and strong enough and won't rot. You can get the Strata at GE Plastic supply. Some just use the strata board by itself.
Cockpit panel
Using fiberglass was a great decision, the job turned out perfect and i don't have to do any painting.
- Hyena Love
Users browsing this forum: No registered users and 9 guests
