weak transom
Matt29
weak transom
Post by Matt29 »
I pulled my B28 last week and took a look at the bottom and such for the first time since I acquired it. Bottom seemed pretty clean, but I noticed that the transom appeared very weak to me. I've heard before that it is one of the weaker areas, but a gentle bump with the palm of my hand resulted in obviously deflection! Just kind of a hollow sound, not rock solid like the rest of the hull. I get the impression a decent mako thrashing off the stern could do some serious damage. I don't think its current integrity would even support a swim platform! Is this common, and I'm just overreacting? Any recommendations for improving the structural integrity back there? Here's a pic of the transom from inside. You can see the light through it in a few spots. Should that support my concerns? I have faith in the experience of this site and appreciate any feedback.
Matt
I realize the pic is poor quality but you get an idea of what I was talking about. I used a flash on the next pic, which makes it harder to see the lighter areas.
Image[/img]
scot
Post by scot »
I have no personal experience with the 28 transoms but I have noticed over the years that this seems to be a common with the 28's??
Based on reading many postings I believe that this is just the way they are....I've been wrong before, and may be again.
I guess your options are;
A. Live with it, or: B. Reinforce it, i.e. coring and more glass.
Call Bruce, he loves glass work.
JP Dalik
Post by JP Dalik »
I'd live with the transom (probably not going to ever be an issue- even the 31's flex) and work on getting rid of the rusty steering components.
Brewster Minton
Post by Brewster Minton »
Spend the money on the steering, it looks pretty shot. Get the transom looked at by a glass guy you trust. just my two cents
If it makes you feel better you could glass in some plywood. just make sure it is fully encapulated! probably unnecessary though.
Kevin
Post by Kevin »
Mine is like that too. I would not be concerned if I were you. I said the same thing to my glass guy. His answer was an inboard boat does not need the thick transom like a outboard boat. Mine has platform, and when all points are secured, ie the braces, it is actually rather strong, but will still flex slightly. Never heard of one of these going down before for that reason.
Ed Curry
Post by Ed Curry »
I have a thin transom also. Next time you're poking around your engines on a sunny day take a look at the hull sides, they're translucent as well. The beauty of the Bertrams are that they knew where to put the glass.
When I put my swim platform on I glassed in four plywood backing plates. I was planning on tieing them into the stringers but I found that the 1ftx1ft pads added a considerable amount of stiffness. Once I bolted up the platform it was rock solid.
bobozinga
Post by bobozinga »
Man, that tiller arm and related rudder hardware look bad. I'd sure deal with them first.
Oz
In Memory of Vicroy
Post by In Memory of Vicroy »
On an inboard boat, even a lowly Hyena Boat, the transom has no stress, it's just a water dam to keep the waves out of the cockpit, so flimsy is OK. If you are going to hang a swim platform off it, beef it up, otherwise just forget it.
Now I will chime in too that your steering tie bar is something you need to address, and now. It looks like the original steel pipe one, and you should shoot it with CX a few times, then wait a week, then rub it down with a Scotch pad and get the rust off. Then either maintain it with regular CX use or replace it with stainless. Otherwise its gonna fail on you when you least can afford it.
Kevin
Post by Kevin »
UV,
Can we atleast repalce, "lowly", with mediocre? It just sounds better. Howz aboutz "marginal?"
In Memory of Vicroy
Kevin, no, the Hyena Boat should remain "lowly". After all, this is a Bertram 31 site devoted to the Best Boat Ever Built. The B31 Faithful have been very graceful in welcoming the owners of lesser boats here, but there is a line we cannot cross. "Lowly" is just a word, but "Butt Ugly" better describes the Hyena Boats, so be thankful for small favors and just accept "lowly".
Yo Fren'
Kevin
Post by Kevin »
UV, That's a big ten-four. Thought I would give it a try....I knew the answer was no! Keep on keepin on. Kevin
IRGuy
Post by IRGuy »
Gee... I won't dare ask you guys what you think of B33s.
Matt29
Post by Matt29 »
Although I understand the "hyena" reference, I am apparently too green to understand it's origin or basis. Perhaps someone could provide me with some insight on that one. That being said, thank you all for your input. It does put my mind at ease about the transom. In regards to the steering, I should have seen that one coming. I realize it's pretty sad. I'm doing the gas tank and steering this winter. I won't even post a pic of the port rudder shelf. It's not just embarassing, but scary. I plan on replacing both with the rudder shelf similar in style to that posted by Capt Pat on the building link. I plan on glassing it in between the outbd stringers and to the transom for a little added integrity back aft. This work needs to be done now, but I don't think oversized rudders are in the budget for this winter. Does anyone here foresee issues with replacing the steering components and rudder shelves with the old rudders and then updating the rudders at a later date?
Thanks again,
Matt
Matt,
You're fine doing your remodeling and keeping the existing rudders. Mine are the same shaft dimensions and will fit your updates at any time down the road...
The hyena boat thing is an Uncle Vic Original and came from pokin' fun at Ernest. While UV truely doesn't like the look if the design, it's all in good Coonass fun. Ernest may even still have plans to paint a hyena on his transom.
Matt29
Post by Matt29 »
Please disregard the inquiry to the "hyena" origin. I have since been enlightened by the "jersey boat builder" posting.
Matt
Matt29
Post by Matt29 »
hehe. Thanks for the info Capt Patrick. It's good to know I can do one thing at a time. I do eventually plan on getting those rudders though. I recently had my first experience trying to run a straight course down the canal on one engine. It's not that difficult...it's impossible! What a circus! No doubt you'll be hearing from me down the road.
Matt
Charlie
Post by Charlie »
Yes the 28B's transom flexes. No reason for concern. When ever you hang something off the hull you should always use backing plates.
In response to my beloved UV. Bertram 31's look unique; almost everyone can spot a 31B. The 28B has a classic look more in keeping with traditional sportfishing boats. They do not look like a hyena dragg'in it's but IMO and my wife agrees. So that's the truth the whole truth and nothing but the truth. hehe
John F.
Post by John F. »
Matt-
I have a B31 with the rudders set-up like yours--the arms attach to the rudders under the shelf rather than on top of the shelf like most B31s (or most I've seen). I had to rebuild my rudder shelves before she could hit the water (they were completely rotted when I bought her 4+ years ago), and I bought Cap. Pat's rudders last year. The big rudders are just great.
If I were doing it over again, I'd do the steering, rudders, and shelf all at once, and change over to the the B31 on top of the shelf set-up. It just looks alot easier to get at everything for maintenance than the under the shelf set-up.
John F.
bobozinga
Post by bobozinga »
I dream of installing Capt. Pat's rudders on my Hyena. Unless you're really a master (and I ain't) handling a B28 on one wheel is really a chore, especially in tight quarters. The standard damn Hyena rudders are just too small for the job.
In Memory Walter K
Post by In Memory Walter K »
Don't feel bad. One engine on a B-31 is a horror, too. I'm working on my 7th renewal on my Captain's license and I won't even attempt close quarters on one engine any more. Walter
Brewster Minton
Your master enough. You made it back to the dock and did not hurt anything. Thats the measure capt.
