East Wind - Spring 2011
PeterPalmieri
Post by PeterPalmieri »
Here is a general update from my to do list back in the fall and winter.
The boat went over to Martins marine in Islip about a month ago now and should be back in the water this coming weekend.
Worked out my Babylon Village slip I will be in the Argyle Basin just south of Montauk Hwy by the waterfall and music pavilion.
Ed Curry was nice enough to donate a Foruno color fish finder FCV600L to East Wind which I had a new transducer installed. The props I picked up from Tony Meola have been installed along with new cutlass bearings.
The old sea cock fittings for the engine SW intakes were replaced with 90 degree valves. Since the thru hulls were in good shape I did not switch over to external strainers.
The old poorly done 110 was replaced, no inverter just two outlets, one in the head and another at the galley.
All the old fuse blocks in the engine compartment have been replaced with breakers.
All the zincs have been replaced and the bottom will get a fresh coat of paint today or tomorrow. And the hailing port still needs to be changed before she goes back in the water.
Also was having the hour meters and fuel gauge moved in anticipation of the pod going in (separate thread). The hour meters were corroded and falling apart, new meters have been installed in the engine compartment at the electricians suggestion. He is also a B31 owner and has been a big help.
The forward bilge pump was rewired as it was spliced with electrical tape in the bilge.
Of course I have the console pod from Capt Pat and seats similar to Bobs, project still TBD. Also thinking about bringing the boat to a buddies yard and put in the lift so I can tear out the trim tabs and remove the sword fish pulpit again Project TBD.
That's it for the moment boat should be back in the summer slip this weekend or early next week. A friend recommended Rising Tide Fuel as a gas delivery service, cheaper then filling up on the water? Anybody using him or a similar guy in the area?
In Memory of Vicroy
Post by In Memory of Vicroy »
Pete - good deal, you are to be commended for not chasing your tail and doing the simple (and important) stuff first. Now enjoy her for a while and you will find plenty more to do.
They are really very simple boats.
In Memory Walter K
Post by In Memory Walter K »
When I had my boat at 3 mile harbor I always had direct delivery of fuel to my slip and it was meaningfully cheaper and very convenient. Yours is Gas so I would recommend delivery only when you are there.
PeterPalmieri
UV,
Simplicity is the key!
I could easily live with a portapotty, a case of Poland spring and some hand sanitizer. Lose the sinks, pump, marine head, fresh water and holding tank. I'm not going to go through the trouble of pulling them out but you get my point. Bare bones.
Pete
PeterPalmieri
walterk wrote:When I had my boat at 3 mile harbor I always had direct delivery of fuel to my slip and it was meaningfully cheaper and very convenient. Yours is Gas so I would recommend delivery only when you are there.
Walter,
Help me understand why I need to be there.
mike ohlstein
Post by mike ohlstein »
PeterPalmieri wrote:Help me understand why I need to be there.
So that when the gas guy pumps 150 gallons of gas into your bilge, blows up, sets the marina on fire, and pollutes the harbor.......your insurance company won't hang up on you when you call.
Mean Team Leader
PREDATOR
Burn Oil
Eat Food
1973 FBC 1286 0273-315
In Memory Walter K
Basic concerns of venting and possible overflow for which you would be held responsible (even with diesel). I'd want the bilge well aired out before closing her up again. Stuff you would normally do, but wouldn't expect a fuel delivery guy to do.
Russ Pagels
Post by Russ Pagels »
He might not know the difference between a rod holder and the gas fill. it does happen,don't ask me how I know.....Russ
1972 31 FBC 315-141-1226
is that good men do nothing.
In Memory Walter K
That reminds me Russ....I had a dock boy fill my gasser with diesel once...ugh!
TailhookTom
Post by TailhookTom »
Mike:
Nice job of cutting it down to the truly important concepts. Barry Soetoro would never want you writing his speechs!
Tom
mike ohlstein
I call 'em like I see 'em......
Mean Team Leader
PREDATOR
Burn Oil
Eat Food
PeterPalmieri
I would plan on meeting him down there the first time. After that if I have to babysit it's probably not worth the trouble.
I did have a gas dock fill my boat with diesel once years ago kind of made for a very bad season.
randall
Post by randall »
i had my boat filled at the dock for five years no prob. i was there a few times by chance. the guy knew what he was doing.
worth it as far as i was concerned.
and much easier than the last few years of the gas can two step.
Glad to see you will be getting to enjoy it. Like UV said do the simple things first. But his comment on a boat being simple, no boat project is ever simple. Ask anyone here how I know.
Craig Mac
Post by Craig Mac »
i have been using rising tide---very happy with them.
I am always there when they come, no issues.
captbone
Post by captbone »
There is another 31 bert already in Argyle Basin right by the gazebo. It is a nice off white and was just painted. It used to be on shore road also. It also used to have a bright red sign on the rear door "Alice? Who the f&^k is Alice?"
I always wondered about the sign and the story.
captbone wrote:There is another 31 bert already in Argyle Basin right by the gazebo. It is a nice off white and was just painted. It used to be on shore road also. It also used to have a bright red sign on the rear door "Alice? Who the f&^k is Alice?"
Now I'll never get used to not living next door to Alice...
PeterPalmieri
I don't know the guy who owns the boat. But we have a mutual friend, says he's a really nice guy. I believe he is a diesel mechanic. I am sure I will meet him down there. I will get the scoop on Alice.
Charlie J
Post by Charlie J »
i sold my first 31 to a guy in babylon a fbc, the window on the door was stained glass, a pic of a fish, anyone know the boat, or if its still around
1968 hull # 316 - 757
TailhookTom
Bare Naked Ladies Alice?
PeterPalmieri
Just added a new set of engine compartment fire extinguishers to the list. Almost there.
TailhookTom wrote:Bare Naked Ladies Alice?
http://www.youtube.com/watch?v=CsrfovOPcjk
PeterPalmieri
When I originally did the survey on the boat it had 17x16 props. We hit 5000 rpms WOT with about 50 gallons of fuel and 4 adults. With those props the boat was pretty consistent at 18.5kts at 2800 Rpms.
I now have Tonys props on, I believe 18x19 and a new set of cutlass bearings. I am hoping the WOT drops to 4300-4400 RPMS and my 2800 cruise picks up to more then 20kts.
Are my expectations realistic? I should be running the boat Saturday, any significant change to how the boat handles at the dock?
Pete
Charlie J
Post by Charlie J »
peter
i think your right in the ball park with thous #s if i rememmber correctly from when i had my fbc with 454 crusaders
That would be better then my numbers...2800 is 17-18 knot cruise for me with 440's.
Are you supposed to max out at 5000 or 4400rpm at wot? Whatever the number, make sure you can attain it at WOT.
Craig Mac
Post by Craig Mac »
Peter,
What are your transmission reductions?
Any idea how much your boat weighs?
PeterPalmieri
Sim not sure what the max RPM should be but I do know it's less then 5000.
I am surely getting 18 knots with the old props.
PeterPalmieri
Borg Warner 10-18-004
Don't know the real weight.
The Transmissions should be 1.5 to 1. With the 18x19's you should come down to around 4400 RPM's. No matter what you do, I don't think you will get much more than a 20 knot cruise. I used to get 19 to 20 at 3000 RPM's with the mercruiser 454''s.
The important part is to get those engines down so they don't over rev. Are you sure your Tachs are not off. 2800 RPM's spinning that small wheel should probably have you less than 18 knots.
Bob could comment on this better than me, but unless your Transmission is something other than 1.5 to 1 and I doubt it is, the engine at 2800 RPM's would be way below the HP/Torque curvbe ratio for you to get that kind of performance out of her. Unless and maybe your transmission is something like 2 to 1.
The reduction formula is on the tag on the transmission.
bob lico
Post by bob lico »
tony you are right in what you say ;should be 1.5 to 1 . 5000 rpm is to high peter . incidently why not warm engines to operating temp. then one engine at time go to wot. in neutral and tell us rpm indicated on tach .of each engine .
Not a great idea on gas engines... Not the same as on governed diesels.
bob lico
Post by bob lico »
i will do it for you peter . i have to know if you at stops or" prop out".capt. we only hold for a second , belive it or not less risk then under load at wot. like a overproped boat .
Michael
Post by Michael »
Gotta agree with capt Patrick on this on - no governor on those gas engines. You risk blowing them up if you go to WOT in neutral
PeterPalmieri
Just got my yard bill and separate bill from electrician. Looks like enough dough and upgrading for a while hopefully. Figuring I have to stop for 150 gallons @ $5 on the way home tomorrow, tack on $750.
The gears are 1.5, I have no reason to think my tacks are not accurate, but anything is possible Hopefully I'll find out tomorrow. Figuring I'll be happy if I can get 20kts at 2800.
I'd be real happy with that too!!
But I'd expect to see 19mph at best if light on fuel, wind at you back, going with current and coming down the face of a wave.
Eddy G
Post by Eddy G »
Peter, I have 1.5 to 1 gears behind my Yanmars with 18 x 18 DJX nibrals and a meduim cup. I cruise mine at 2750 rpm which gives me 25 mph or 21.75 knots. It's a B28 but, that shouldn't make that much difference.
Eddy G.
PeterPalmieri
sim wrote:I'd be real happy with that too!!
Something has to be up then. I have been clocking 18 kts or 20.5 mph with the old props. The survey report shows:
15kts at 2500
19kts at 3000
22kts at 3500
24.5 at 4000
29.5 at WOT (5000 port 4900 starboard)
It's not my GPS as we confirmed my unit and a separate hand held.
If everyone else is not getting similar results then my tacks must be off. Not something I am going to worry about to much.
Eddy G
Post by Eddy G »
19 knots at 3000 rpm is what I use to get with my 170 Yanmars. 1.5 to 1 gears with 18 x16 nibrals with very little cup. I had to use the tabs to bring the bow down some and it still was pushing a bit of water. So probably more slip than at 22 knots.
Eddy G.
Craig Mac
Post by Craig Mac »
not sure what motors you have---but i would be suspect of big blocks turning 5000 rpm ---or you are turning props that are smaller than 18 X19
PeterPalmieri
Just bought the boat in the late fall it came with 17x16 and got up to 5000rpms. Just had the boat switched over to 18x19 to bring down my WOT and increase my cruising speed.
454s
In Memory Walter K
I would guess that should bring her down to about 4700 or a little less. Easier on your engines and probably better performance. Let us know. Good luck.
JP Dalik
Post by JP Dalik »
We taking bets.
I'm gonna go with 4500
whose next
John F.
Post by John F. »
I had 18x18s 3-blades and 17/15 w/cup 4-blades on my 69 FBC w/454s and 1.5/1 Gears. About the same numbers with the 3 and 4-blades. Clean and light, she ran about 19/20 knts at 2800 rpms, and 22 knts at 3000 rpms. When I first got her, I got about 30-32 knts at 4200 rpms best I can remember. I stayed away from WOT with my old gassers. I personnally would never have taken my 454s to WOT unloaded--can't imagine.
Your cruise numbers sound OK, but your WOT numbers have to be way off. No way should you get 5000 out of 454s with those cruise numbers, and if she is actually turning 5000, then you should get alot more than 29.5 knts. Sooo, being that you verified your speeds, I'm guessing your tachs are off. No bets until you check your tachs.
Peter, every boat runs a little different.
You will find out soon enought and I hope you are pleased!
bob lico
Post by bob lico »
i guess after running 496" at 9000 rpm for years it is a little bit easier for me to run a 454" 330hp at 4800 rpm a few seconds with linkage off and thottle in hand i set new stops however if indeed 5000rpm in gear engines are real sweet , personally i doubt it.
I am bettng that the props gets Peter down to 4400. 19 knots at 3000 RPM sounds right but the top end is way off.
If Peter gets down under 4500 then he is good. Over 4500 he needs more cup. Those props should have a slight cup to them. I don't remember how much. But like I said, with the 454 Mercruisers I used to hit the top around 4200.
Anyone else willing to join the RPM lottery.
In Memory Walter K
I have found that cupping works very well on Diesels because it works at the top end of the rpm scale and cruise is 2-300 under WOT. On Gas engines where you're actually cruising 1000+ under WOT, does it work as well?
bob lico
Post by bob lico »
yes it does walter . cupping works at all rpm because instead of incresing pitch thus churning white water we increase effiency buy pushing more water (better bite) and more effiency at any given rpm. (less slip).
walterk wrote:I have found that cupping works very well on Diesels because it works at the top end of the rpm scale and cruise is 2-300 under WOT. On Gas engines where you're actually cruising 1000+ under WOT, does it work as well?
Walter, with gassers even at a 1000 off WOT our wheels will usually be turning faster then diesels at 200 off the pins. We do not have the torque to push big wheels, so we spin the lil' ones faster. A cup can play a big roll on our mid-range to top end performance.
PeterPalmieri
19.5 @ 2800
32 @ 4300 WOT
Users browsing this forum: No registered users and 34 guests
