20'bertam moppie
20'bertam moppie
:cry: this 20'moppie has me pulling my hair out.there is no way in hell you can put a 525hp sc mercruiser in that engine compartment of a moppie made into a baron.to clear the engine compartment covers you have to mount the mercruiser engine 1" off the bottom and the supercharger sticks out the top with either stock carbs or fuel injection.
i cannot come even close to the "x" dimention needed for the bravo three drive.rocket can you shed some light on this,i know you once posted a big block 20' bertram but the supercharger add to much height and i cannot remove,the engine (piston compresion , cam,etc) is build for a "huffer"
what are your or anybody else for that matter feelings about a bracket and a 300hp suzuki 4stroke we have 6 left (out of a trailer truck full )and i can buy it "right".do you think i would destroy the look of a 20'bertram is sure is a hell of alot easier and much better on gas probaly 60mph+ base on another with a 250hp e-tec at 52mph.i can put the tank in without tabbing and move fore and aft for perfect trim.
Whats the weight of that suzuki? Could be a little ass heavy, despite the added bouyancy of the bracket...
I'm not a big fan of outboards on any of the Ray Hunt Bertrams, but thats just me. Admittedly, some guys are really doing some nice conversions on their B25's, and B20's... I guess that on a Moppie, it's not soooo bad. But, if you took the time, money, and effort to convert it to a Baron, then I'd say an outboard is outta the question.
If you're ok with 300hp, why not put one of the newer 300something hp GM5.7's in there?
- ZeroCavity
300hp suzuki weights 550lbs and that small block (383) and a 525 hp are pretty close in weight big block 525 has tubular(stelling)headers,alluminum cyliderheads, alluminum intake,no fuel pump, alluminum water pump,aluminum racing oilpan,etc.the suzuki is about half the weight of the 383"/bravo 3 set up.the finish set up in outboard version would have the wrap around rear seat at the trasom.elimnating the traditional engine hatches.
robbie this is the short shaft but either way if you look at the coversion of a 20'bertram on the bertram 25 web site with a 250hp e-tec the numbers look real good and like i said i can move the fuel tank forward.
thank you guys for all the inputs but bear in mind this is a limited use boat built for my son.the 525hp engine was avaible at a price you can`t refuse and the 300hp is 14thousand ready to run.my first choice would be a yanmar 260hp diesel/bravo-3 but there are to many problems with this power comb. as of this date.i did not covert the moppie to a baron yet because i wanted to finalize the powerplant the mercruser 525hp is here to take measurements and a wood mockup this is how i came to the conclusion that it just won`t fit.the jupiter bracket is at the mariner to trial fit.buju a gmc 350 would work but again that is a over the counter buy.we have no small block freebee`s this year.on the subject ;the small blocks seem to hold up much better than big blocks with the fuel crisis(achohol).
Bob - I wonder if the Baron deck height is taller than a moppie ? I can get down and do some measurements. Would an arneson give you a lower x dimension? I love the idea of 525 HP in that hull - I got 320 and running it at WOT is so easy, no skill required (which matches up nicely for me!) I would like to put more HP in mine as well, so I'm happy to do some homework if it would help. I guess dry sump is not a help as bottom clearance is not an issue - x dimension is. It might be blasphemy, but a scoop of bubble on the hatch, or do you want a sleeper?
bob- 250etec ho weights under 510lbs, 100 pounds off the back of the boat is huge in my opinion.
I went through all this picking a motor for our whaler project, weight was a big issue so we went with the 250 etec. It is a great motor and the owner does not drive it gently.
im going to go off topic a little here and put some non-bertram pics up so if that offends anyone I apologize in advance!
we have since added 4" of setback and raised the motor, and this winter the decks are coming out and we are putting stringers and bulkheads in so he can take the thing airborne once in a while
we also changed the bar as well
Rocket- Bob is going to hang an outboard off the transom, somehow your suggestion seems far less blasphemous.Rocket wrote:Bob - I wonder if the Baron deck height is taller than a moppie ? I can get down and do some measurements. Would an arneson give you a lower x dimension? I love the idea of 525 HP in that hull - I got 320 and running it at WOT is so easy, no skill required (which matches up nicely for me!) I would like to put more HP in mine as well, so I'm happy to do some homework if it would help. I guess dry sump is not a help as bottom clearance is not an issue - x dimension is. It might be blasphemy, but a scoop of bubble on the hatch, or do you want a sleeper?
buju you have your act together yes the 2' bracket gives bouyancy but most important it puts the prop 2' from the airated water coming off the bottom of the boat at the transom.also the 2' act as a longer running plane making the 20'betram feel like 22'.as to the other guys comment they have no clue but i will give you a hint take a good look at the suzuki 300hp water pickup,lower unit and prop.lets see your are cocerned about 100lbs ok nobody can drive the boat except a child ---no passengers.should have used a challenger21' instead of a "brick".
rocket the 525hp mercruser is the baby high performance engine very docile this is entrance level and they go to 1200hp off the shelve.all hp mercrusers have dry oil sump.the problem with the scoop is the baron has a split engine cover that is rounded to meet the rear deck a scoop on a race boat design is a one piece unit with the p-51 mustang fighter plane shape held in with race pins.don`t want to go this route.i will take pictures of the 525hp and post.
Bob we go through this alot with different boats, the bracket will not have enough bouyancy to counter the weight of the bracket itself and the motor to make the boat sit as if it came from the factory.
If the boat is going to be a trailer boat then it might not be so bad, but on some boats- and I will admit to not knowing the deck or drain system of your 20'- it puts the drains below waterline and now you have a boat that does not self bail being left in a slip- so take all that into consideration.
Bob, that is very sexy - I can't believe that it won't fit. Can you put a shortie lower unit on the drive?
As far as the hatch is concerned - the split hatch is actually a bit of a pain - If you had a single rear hinged hatch on gas shocks, you could do your P51 scoop and fit that beast in the engine bay. I would love to hear your results about 525 hp in that hull.
To give you a little reference on the weight of an outboard, we have a 1965 Bahia Mar with a Honda BF150. The wet weight of the BF150 is around 500 pounds and our boat is self bailing. I would be surprised if a 300 Suzuki ( only weighing 100 pounds more) would make it so it won't self bail at the dock. A 300 Etec is the same weight as our Honda, so you would definitely be self bailing. A 250 Suzuki will be the next engine we buy for our Bertram.
i guess i should have mention the self bailing cockpit goes into a scupper which is piped thru the bracket and out the stern of the bracket.o.e.m. for everglades and jupiter.never a problem.the reason i laught at the 100lbs between the suzuki and the e-tec is -HELLO 4stroke capable of a bigger diameter prop and more torque.you can`t match the lower unit of the suzuki unless you are dealing with a 700pound race hull then mercury if center console 4stroke only option.34'&38' ceter consoles can take advantage of the yamaha 350hp.we have one here with triple 350hp "bump" to 400hp.talk about heavy! 750lbs each this 38' jupiter does near 70mph and cruise at 53mph.went to the "deep" last week in 2 hours about 85 miles out of fire island inlet.
You seem to have all the answers Bob, so need for us!
But to further explain- when you have a deck LOWER then the waterline of the boat you no longer have a boat that bails on its own, there will be water on the decks and then you are relying on bilgepumps to keep you afloat if there is a storm or your drain clogs.
Im sure on the Jupiter, which seems to be the best boat in the world according to your statements, the decks are HIGHER then the waterline, so yes plumbing drains out the boat is not an issue.
We did a older Mako over the winter that had a converted full transom with 2 4 stroke motors hanging off the transom, the boat would fill with water and if the bilge pump would have failed the boat would sink.
We raised the deck almost 2 inches because the owner did not have the funds to put a single motor or 2 lighter motors.
I just dont understand your point of the thread if people offer advice and all you do is laugh at us?
yea but robbie i still no nothing about boat painting and a mere rookie at fiberglass work.i just happen to be around these outboards and it wears on you don`t really care one way or another just trying to be helpful with ideas that have been built and proven to work.we have damm near every center console made at the 3 locations it is just easy to phot those on the hard.
jspiezo, this is what I got so far
The extra motor weight shoves the Mako's scuppers underwater, so the deck will not drain at rest.
The deck was made higher to compensate for the extra weight and now allows the deck to drains out thru the scuppers. It no longer relies on the pumps to remove rainwater, or a wave breaking over the side etc.
What that has to do with the Baron, well Bob has several options, some of which will add a substantial amount of weight aft and Raybo was explaining the deck will not drain if it is below the waterline. Pictures of nicely powered Non Bertrams have been flying back and forth to explain their points, with a few real good shots shots of Zero Cavities Bertram to start off. (Thank you for those Bertram shots, very nice pictures)
As to the parts about the "brick" and kids driving without passengers...I'd have to guess it has to do with the lower end sitting too low... but I'll conceed, I am pretty much lost there. But I do intend to tune in tommorrow for the conclusion, same Bertram Time same Bertram Channel.
I think Bob was just venting about his issues trying to shoe horn a motor into his boat.
Bob- I know who makes those scuppers on the boat, I have seen them before. The Mako is now fine, we not only raised the deck we removed over 150 pounds, which on that boat was huge. The owner is beyond happy that his boat can sit in the middle of a terrible Florida storm and stay floating without relying on his bilgepumps.
sim you got it as for the child explanation in the post i was referring to the concern of 100pounds differance between the e-tec 250hp and the 300hp suzuki.that weight is like having a extra person the weight of a child aboard ok.the photo. of the stern of the center console show how the builder ran a pipe from the inside scupper of the boat THRU the 2'bracket with a one way scupper at the water edge of the stern thus engineering a foolproof solution to draining water from a self bailing cockpit while the boat is at rest.under power this one way supper is not necessary.the brick or ironing boart is referance to a whaler in the great south bay (not a lake).i don`t have opinion nor do i care about outboards but the fact of hanging a 300hp susuki on the back of a 20' bertram brought up the concern of the cockpit not being able to drain that is why i posted the picture of the cc solution.i hope this clears up my post .seems like i cannot take any short cuts when i write the original subject becomes lost.the pictures also show the lower units of the susuki ---far more streamlined then the e-tec but most inportant swing a 16" prop rather then the 15 1/4" of the e-tec that is were the big differance in performance comes from mounted on a 20'bertram which is pretty heavy as compare to high performance 20' boats.the 4-stroke would give better performance over a two stroke because of the increase in torque.
Users browsing this forum: No registered users and 25 guests
