B31 Sportfisher Outline Hi-Res
JPRS51
Post by JPRS51 »
I just finished creating a hi-res image of the B31. Copied it off of the best diagram I had. About to start a project managing the overhaul of several B31's and developed this so the client could play with color combos and such. Email me at jprs51@yahoo.com if you would like a high resolution copy of it.
Jeff S
JPRS51
Post by JPRS51 »
I also have it in a dxf autocad file and can provide it in eps as vector artwork.
Jeff S
Post by Dug »
So, does that mean if I get the .dxf file, I can turn it into 3D, and then throw a chunk of aluminum in one of the VKC's and have a smokin' new mini B31?
Post by Dug »
Ok, someday I will get better spelling for Christmas...
I meant the VMC, not VKC...
JPRS51
Post by JPRS51 »
I am not sure about that. I do nto know a thing about Autocad. I did this in Adobe Illustrator and then just exported it as a compatible autocad file.
Jeff S
thuddddddd
Post by thuddddddd »
Dug, if you have a cool little machine like that, why don't you throw a pic of a bow chock in it? then we could all have cute little bow chock copies.....
randall
Post by randall »
first thing i thought of
It's an Old post I know...
The price of running the Bow Chock from a solid block of 316 SS with a small enough stepover to provide an even adequate appearance would be mindboggling pricewise. Even then you would have a huge polishing cost on top to boot. Casting was and is the wise choice. Now in alum that would be another story.
Post by Dug »
Sim, you would know, and you are right.
Timmy, That is why I said aluminum.
To machine stainless...that is tough... Worse in many ways than tool steel.
