In line/stand by pump
Post by Yannis »
Is there any pump that can be connected IN LINE on a hose/tube so that it be activated ONLY when there is water entering one side? There shouldn't exist an outside floater to activate it.
(The pump can be turned on or off from the switchboard but it will only operate when water enters from one side; the presence of water in the entry side should automatically activate it).
Thanks.
Re: In line/stand by pump
Kinda sound like a smart bilge pump. The pump cycles at a set time period, if it feels the resistance of water the pump turns on.
Post by Yannis »
Yes, if it feels water resistance it should activate.
Is there such a shower pump?
Sheer Folly
Post by Sheer Folly »
Yannis,
Great pumps, but if you sleep on the boat, and are a light sleeper, you will hear it go on and off as it activates to check for water.
Also, if left active during Winter layup, it will run your battery down.
Just an FYI.
Richard
Post by Yannis »
Carl, Richard, thank you.
Unfortunately this pump needs to pull water from a bilge;
what Im looking for is a completely closed system, if it exists, whereby the pump collects DIRECTLY from the shower floor valve (through a IN port) and discharges outboard (through an OUT port) without any water being visible in the process.
This pump should operate ONLY if it receives water from its intake and then remain shut until it senses water again.
Does anybody make such a pump?
ktm_2000
Post by ktm_2000 »
yannis,
you are not looking for a pump, you are looking for a sensor you can add to a location which can contain water which in turn will turn on a pump if water exists.
Post by Yannis »
No, ktm, I want to get rid of my shower sump completely and send the grey water directly overboard, the problem is the shower floor is lower than sea level.
Any ideas? :-D
ktm_2000
Post by ktm_2000 »
below water line, gonna need a pump one way or another. I have a bilge pump switch that has no moving parts
https://defender.com/en_us/water-witch- ... #493=19515
I think you are looking for something that could live in a hose and turn a pump on when it sees water, I am not sure that exists.
Yannis-
Shower drain flows into a shower pan mounted under shower which contains the pump. Pump "sees" water and turns on discharging overboard../being grey water you want it out so install one way valve. Pump I have seen is oftern a bilge pump with floating switch...but could be smart pump or as KTM said a water sensor.
Or go ready maid
https://www.wholesalemarine.com/rule-80 ... in-system/
Post by Yannis »
I want to get rid of the pan and the float and direct the gray water out with a hose that incorporates an inline pump that gets triggered by that same water.
I don't want the shower water to fall into a pan, trigger the float that starts a pump that sends the water overboard.
The question is, does such a pump exist?
I don't think what you are looking for exists. You might want to consider saving water.
https://www.amazon.com/Nurture-Disposab ... B0837WS38N
Post by Yannis »
LOL Tony, revolutionary indeed!!!
Users browsing this forum: Bing [Bot], Google [Bot] and 73 guests
