New paint job
saburke17
New paint job
Post by saburke17 »
So she's finally in for facelift, The paint job was over 20 years old and the clear was peeling of in a few area's. I removed the Teak on the transom as the bottom board was rotting and it was on its last legs. Stripping that teak was not a fun project, but i found out that a multi tool with and adhesive blade peels 5200 off like butter. I made a few changes, the side air boxes are being deleted, Glassed over all the side thru-hulls, new Rubrail from ABT and will be installing Aquatraction on the fore decks and down the sides in front of the main windows and on the helm.
MarkD
Re: New paint job
Post by MarkD »
Looks fantastic. The color looks great and the new rub rail will finish it off. What was the old name and hailing port?
saburke17
Re: New paint job
Post by saburke17 »
Matchmaker out of Fire Island
Re: New paint job
Very Nice !!
Ironworker
Re: New paint job
Post by Ironworker »
Extremely nice!
Rick Ott
Fly N Fish
1969 B31 Flybridge
Hull # Don't have a clue
Raybo Marine NY
Re: New paint job
Post by Raybo Marine NY »
i remember that boat when Jimmy did it
what color are you going with ?
saburke17
Re: New paint job
Post by saburke17 »
AwlCraft AquaMist
saburke17
Re: New paint job
Post by saburke17 »
Raybo Marine NY wrote: Apr 12th, '22, 15:43 i remember that boat when Jimmy did it
I think Jimmy may have cut some corners, unless someone else did the teak install
Raybo Marine NY
Re: New paint job
i could be wrong but I think he subbed that teak work out. I kind of remember having a conversation with either him or his guy Dennis who did most of the work there. I never inspected the boat up close but would pass by it on land a lot. Has to be 15+ years ago .
aqua mist is a different color than what you had, but im sure you already knew that
saburke17
Re: New paint job
Post by saburke17 »
The color currently on the boat is Aquamist, going with same. I originally thought it was seafoam but when you put the color chart up it's not even close. The teak on the helm was screwed down with fine drywall screws. Every single one snapped when I was removing it. The Transom had screws, nuts and bolts, multiple sizes amd no rhyme or reason to a screw pattern.
Raybo Marine NY
Re: New paint job
Your first 3 pictures look like ice blue, then the other pic looks more green, they are somehow remarkably close to each other even when you have them side by side in the yard. I had 2 I had just painted of each color and even I was doing a double take
It doesn’t really matter that much because your painting the hull anyhow
Re: New paint job
Looks Great.
How long will she be laid up?
saburke17
Re: New paint job
Post by saburke17 »
i think two weeks and she'll be done, then im doing the Cream color by roller and few other small projects like 1kw ducer, new throttle controls and new Aquatraction
saburke17
Re: New paint job
Post by saburke17 »
ok, so 130 man hour later we are now in primer. We prepped and repaired all the crazing from where the hull and top decks are connected. We're gonna spray the toe rail so when he puts the rub rail on we have to mess with that area again. They ended up stripping the whole paint job off with razor blades. Took 4 guys 4 hours for the whole thing. Will be spraying the toe rail this week and then next week is the hulls turn. One thing i will say is this guys work is top notch, Every single hole and patch was ground out and fiberglassed back a little higher and then sanded back down. The only filler he used was to fill small scratch or voids. Check out this brand new MJM he just painted, 50' triple 600 Mercs. Does 60 knots wot at $1000.00 bucks an hour lol
saburke17
Re: New paint job
Post by saburke17 »
She's done!!! Cant be happier with the results. 193 labor hours is what it took, if its in direct sunlight it look white, in the shadow is blue and sun behind it she's green. All new rub rail and black widow bottom job. I did a 2" cream boot stripe with a 1/2" hunter green accent
Re: New paint job
Nice work. She looks great.
Snipe
Re: New paint job
Post by Snipe »
She came out really nice. Looking fresh!
Jason
Re: New paint job
WoW !! Shes looks most impressive.
JeremyD
Re: New paint job
Post by JeremyD »
She's a beauty
Re: New paint job
Ooooweee! That is pretty! Nice name!
Oldcreek
Re: New paint job
Post by Oldcreek »
Shazaam!!!
Very nice!
-Wil
Wil M.
1969 B31 Bahia Mar w/ Factory Hardtop, #316-764
2014 G3 14'
CamB25
Re: New paint job
Post by CamB25 »
Looks great! Congratulations!
