My boat deck were restored with the idea of installing the side panels which I not plan to abandon. I'd like to install the open side look as in this photo or similar as I need room for gaffs, harpoons, boat hooks etc.
https://www.dropbox.com/s/r5xvztgrqf9fe ... s.png?dl=0
What I currently have can be seen in these photos which is about a 3 to 5" gap on the sides and maybe 6 to 8" on the stern.
https://www.dropbox.com/sh/lkc1sl7p8suh ... f5Sra?dl=0
My original plan was to build some new side panels that would be removable to install around the sides between the gunnel and current deck panels . But after having looked at several other boats, I'm beginning to think that perhaps I should just glass in a shelf to the gunnels and stern and let the current deck panels fit next to them.
Perhaps something similar to this but with a lower vertical profile. I was considering glassing this shelf around some rigging tubes or forming a rigging tube with then new shelf.
https://www.dropbox.com/s/awdekq6331n2s ... t.jpg?dl=0
So build something removable or glass in something permanent?
Completing my Deck Floor-Need advice?
Rick Ott
Carolina Reaper
Hull # Don't have a clue
Carolina Reaper
Re: Completing my Deck Floor-Need advice?
Rick
While I still have the side panels, the removal of them allows you to get your feet closer the hull sides allowing you to brace your legs against the sides if needed. The shelf defeats that purpose.
I would try and build a gutter system the existing deck could rest on.
Rick,
That step is part of the molded 28 deck floor. This is not a 31.
The vertical gunnel supports have holes in them so that you can slide longer objects through, like this red broomstick.
Tony,Tony Meola wrote: ↑Jan 17th, '21, 00:22 Rick
Thanks, I'm very likely going to be mounting a toe rail at the bottom of my racks once they get installed. If I can glass a gutter or shelf to the gunnel that would be the strongest option. I have also considered just extending the current floor panels but I don't that would look very good.
Rick Ott
Carolina Reaper
Carolina Reaper
I knew it was a 28 but I've been looking at a lot of cockpit floor details or various boats. You comment about the vertical gunnel supports gives me an idea about how to mount my harpoons, which off course requires more work.
Rick Ott
Carolina Reaper
Carolina Reaper
Users browsing this forum: Kevind767 and 12 guests
