Are you sure the sending unit or the gauge is not causing the temp difference?
Did you shoot the engine with a temp gun to see if one asrea was running hotter than the other?
And finally, did you use the temp g in to check the temp of the water running out the exhaust?
Got an engine prob Cummins B series any ideas maybe?
Re: Got an engine prob Cummins B series any ideas maybe?
- scenarioL113
Tony, I did install a brand new temp sender last month. I am not 100% sure but will use a laser thermometer next trip out and check diff areas on the block and confirm the sender as well.
I will try to check exhaust water temperature. Thanks
1971 28 Bertram
4BT Cummins
9-11-01 NEVER FORGET
4BT Cummins
Good to know you overcame this and thanks for sharing the process and outcome.
Best,
Stephan
Best,
Stephan
Users browsing this forum: Bing [Bot] and 70 guests
