Reverso OP6
Reverso OP6
Mine is not working should I rebuild or replace ? easy to rebuild ?
Re: Reverso OP6
Isn't working how? Motor's not turning? Won't pick up liquids?
Re: Reverso OP6
just found this http://youtu.be/89EqmxFtKHU" onclick="window.open(this.href);return false;
Re: Reverso OP6
kicks in and out and hardly works in one direction looks corroded
Re: Reverso OP6
Remove the pump assembly and try the motor. If it spins freely in both directions the problem in the pump. If not the problem is in the motor. If it's the motor, dissemble slowly and pay attention to parts configuration, clean it up, shoot it with CX, reassemble, and try it out again. If the pump is the problem go for the rebuild kit.
Re: Reverso OP6
CaptPatrick wrote:Remove the pump assembly and try the motor. If it spins freely in both directions the problem in the pump. If not the problem is in the motor. If it's the motor, dissemble slowly and pay attention to parts configuration, clean it up, shoot it with CX, reassemble, and try it out again. If the pump is the problem go for the rebuild kit.
Thank you Captain
I pulled the motor and noticed the fuse is good but looks like cooking oil spilling out and some corrosion.
Going to open clean new fuse give it a go.
Want everyone to know how much I appreciate the site you guys are the best worth your weight in gold just need to get our wife's to agree to this.
Re: Reverso OP6
I took it apart motor was frozen so I worked it free then used a drill on it back and forth got it nice and free then hooked the motor up to 12-V and it worked great but the switching on the top of the motor is shot but impeller looks great hooked it up and connected reverse polarity worked great 5 gallons in a few minutes
Users browsing this forum: Google [Bot] and 50 guests
