Corrosion X
- Russ Pagels
Corrosion X
Should you spray the entire engine with corrosion X. I have it mixed with 1/3 lacquer thinner so it can be sprayed. on a cold engine, warm, I don't think a hot engine would be a good idea, any thoughts, thanks Russ
1972 31 FBC 315-141-1226
is that good men do nothing.
Re: Corrosion X
Russ,
Shouldn't make much difference, but a warm engine would have less moisture standing...
- MarkS
Re: Corrosion X
Stupid question of the morning,.....why the lacquer thinner?
Re: Corrosion X
Mark, not a stupid question at all if you are not familiar with the viscosity of the product. The thinner allows it to be sprayed with one of those plastic hand pump sprayers; otherwise it is too thick for spraying.
- MarkS
Re: Corrosion X
Thanks Tommy. I use it liberally just never thought about using it as an anti-corrosive over the entire engine. :)
- Russ Pagels
Re: Corrosion X
Thanks guys, done and done..Russ
Users browsing this forum: Google [Bot] and 38 guests
