6bta question
- Russ Pagels
6bta question
Hey a quick question on my Cummins 6bta 250hp engines. Cummins has a great site the
cummins quickservice online. my question is with my engines, is it the water jacket after cooled or the sea water after cooled. I think it is the jacketed but not sure. thanks for your help...Russ
1972 31 FBC 315-141-1226
is that good men do nothing.
Re: 6bta question
After cooling is a term usually used in reference to charged air (as in after the turbocharger and/or supercharger)... Cooling the air reduces its volume thereby allowing more air (oxygen) to be pushed into the cylinder... More air means more fuel can be injected...Russ Pagels wrote:is it the water jacket after cooled or the sea water after cooled
FWIW, I have never heard of after cooling the water jackets... And cooling the sea water doesn't serve any purpose that I can think off of hand...
Re: 6bta question
Navatech wrote: After cooling is a term usually used in reference to charged air (as in after the turbocharger and/or supercharger)... Cooling the air reduces its volume thereby allowing more air (oxygen) to be pushed into the cylinder... More air means more fuel can be injected...
Reduces Global Warming...its in Obama's plan...
Re: 6bta question
I don't know about that but I can see where one would colder exhaust water... Having said that, the way to achieve would be by increasing the RW flow... I.e. a pump with more capacity... Adding a cooler would be far more complex... KISS...Carl wrote:Reduces Global Warming...its in Obama's plan...
Re: 6bta question
Your after cooler is fresh water cooled, 180 deg.good news is no salt corrosion, less than good news is 180 cooling water. Works good last long time. Bill
Bill
Re: 6bta question
Thanks Bill.
Russ, your question was as clear as a bell. After cooling done by sea water or fresh water.
- Russ Pagels
Re: 6bta question
thanks for all of your help...Russ
Re: 6bta question
, see if I got this right. Gear oil heats the sea water, sea water cools the fresh water, fresh water cools the compressed air, Fuel mixes with compressed air ,boom, piston goes down, love good rum, don't have any, what was the second law of thermodynamics again?
Bill
Re: 6bta question
Newton's Inverse Law Of Thermodynamics
" If you don't do anything...
Nothing will happen!"
Re: 6bta question
If I recall, the 250hp 6bta is the highest hp 6bs that uses a closed circuit fresh water cooled, after cooler. Which IMHO makes that engine highly desirable from a low maintenance standpoint. I had a nice afternoon boat ride in Capt DQs 31 with the 250 6bs, that combination in a 31 is very nice.
Users browsing this forum: Google [Bot] and 313 guests
