test for ethanol
- Russ Pagels
test for ethanol
there is one gas station in the area that sellsl straight gas. I just want to make sure that he's not blowing smoke. the 2 cycle engines on the leaf blower and weed whacker have been in the shop for repair twice and I was told that it was the ethanol .I could not find the post for the simple test. thanks Russ
1972 31 FBC 315-141-1226
is that good men do nothing.
Re: test for ethanol
POR 15 used to sell a kit but the link that Sean B posted for it no longer works...
Here's a Google Search: http://www.google.com/search?q=ethanol+ ... age=1&rlz=" onclick="window.open(this.href);return false;
- Russ Pagels
Thanks Pat. Thought I remembered a home made kit some one had made up . thanks again. Russ
Russ: I bought this, but you could do the same thing with a Ball Mason jar and a sharpie. Fill with water to the black mark about 1/3 of the way up. Fill the rest of the way with fuel. Shake up and let sit for ten minutes. If the water line rises the alcohol is separating out with the water making it look like the waterline has risen..
http://www.baileysonline.com/Tools-Outd ... Tester.axd" onclick="window.open(this.href);return false;
- Russ Pagels
thanks Rawleigh, I thought there was a quick and easy way to test for it..Russ
Users browsing this forum: No registered users and 20 guests
