impellers
Terry Frank
impellers
Post by Terry Frank »
Hello faithful,
A couple of years ago UV hooked me up with a source for a better grade raw water impeller for Cummins engines. The time has come to order replacements and I do not remember where Vic directed me too. Please advise.
Terry
Terry
Re: impellers
Frank,
That'd be Tony Athens & Seaboard Marine in California... http://www.sbmar.com/smx-seawater-pumps.php" onclick="window.open(this.href);return false;
Terry Frank
Re: impellers
many thanks amigo.
Terry
Terry Frank
Re: impellers
Sent my thanks and update to your last known pm address but it failed. Many thanks again.
Terry
IRGuy
Re: impellers
Post by IRGuy »
Terry..
Glad to see something from you.. it has been a while.
You might want to try a set of the new Cummins impelllors.. they have a threaded piece built into the center of the outer face where you can run a bolt into the threads and back the impellor off it's shaft.. much easier than trying to pull them off with pliers or screw drivers. DeMann has them in stock..
While I have high regard for Tony Athens and his stuff one of the regulars on the B33 forum posted a while ago that he was dissatisfied with his Seaboard impellors... saying he thought his wore out prematurely. I just installed a set of the new Cummins in both my pumps about 2 months ago.
Users browsing this forum: No registered users and 78 guests
