rudder shelf
rudder shelf
what thickness of frp would be sufficient for the rudder shelf took my deck up and realized the deck support went through the starboard side so I want to rebuild it better of coarse
Re: rudder shelf
Go to Capt Pats tips section, thats how I made my rudder shelf. Two layers of 1/2 okume plywood epoxied together then covered with 1708, tabbed and fillet to hull, should last a few more years...BH
Re: rudder shelf
thank you sir yours came out great
Re: rudder shelf
I did a similar process, dry fitted the parts out of laminated coosa board, removed and covered with 1708 and thru bolted back into the stringer system, n mine is mechanically attached with bolts, fender washers and nuts, no tabbing used
Re: rudder shelf
Tom
I used 3/8 inch Fiberglass u channel that we bolted in also. You can stand on it and it does not even sag.
http://www.mcmaster.com/#standard-fiber ... ls/=nkgr4w" onclick="window.open(this.href);return false;
Users browsing this forum: Google [Bot] and 62 guests
