air filters
- Russ Pagels
air filters
Any one running a Cummins 6bta 250hp, would you please tell me what brand name and part number are you using for your air filter. It came with Duralite
dc179Ca can't find any place on line to buy them. thanks Russ
1972 31 FBC 315-141-1226
is that good men do nothing.
Re: air filters
Russ...
When I wanted to replace my air filters the Cummins dealer didn't have mine in stock, so I bought a two part cleaning kit.. lots cheaper.
Part 1 is a cleaner that you spray on the filter.. it washes the dirt off.
Part 2 is some kind of oil you spray on the clean filter.. it stays somewhat sticky, I assume to catch the dirt that is in the air that is drawn into the filter assembly.
Not sure if this is as good as installing new filters, but it seems to work OK.
Re: air filters
Will you be coming to Long Island in the near future? I have a brand new pair.
Re: air filters
bob
going down next month, if russ wants them ill bring then down for him
1968 hull # 316 - 757
- Russ Pagels
Re: air filters
Thanks Bob, Charlie if you could bring them down that would be appreciated. Charlie is this the big move? thanks again Russ
Re: air filters
yes russ, ill get a hold of bob, and run out there
will be leaving the 13th of july
- Russ Pagels
Re: air filters
Bob, got your PM no problem. Charlie, Bob just saved you a trip wrong filters...Russ
Users browsing this forum: Bing [Bot], Google [Bot] and 97 guests
