Recommendations for prop work.
Stuart Cooperrider
Post by Stuart Cooperrider »
Can any of the faithful recommend a prop repair, reconditioning shop in my area. I'm on Cape Cod. Good using any place between here and Providence, RI. New England Propeller comes up as closeby in Plymouth. Dont know anything about them. Read some reviews about PropScan in Middletown, RI. but know little more.
These are bronze 3 blade off my 31. Slight repair work needed on one. Other appears fine but it's probably time to have both overhauled.
And what would be the typical charge?
Thanks in advance.
Go Bs.
Stu
TailhookTom
Re: Recommendations for prop work.
Post by TailhookTom »
Hale Propeller in Essex, CT is great. Nothing like watching a guy 6'5" and 280lbs smack the crap out of you prop and then give it back to you perfectly balanced!
Stephan
Post by Stephan »
Mike at Ocean Props 401-848-7877 http://www.oceanpropsri.com/" onclick="window.open(this.href);return false; gets our props every winter for a check. He has been very responsive and communicates well when more than just a check was needed. He also will lend out a prop puller if you need it.
Go B's
Stephan
Stuart Cooperrider
Thanks for the recommendations. Ocean Prop in Middletown is very convenient.
Stu
gplume
Post by gplume »
H & H on the northbshore did mine...no complaints.
Go B's
Giff
Users browsing this forum: No registered users and 379 guests
