Trying to remove all of the old coolant from a pair of 3208T's in my B38 has always been a problem.
Any suggestions for removing all the old coolant, short of removing a freeze plug? (said tongue in cheek. I don't really plan on doing that)
Removal of coolant in 3208 Cats
- Capt.Frank
Re: Removal of coolant in 3208 Cats
I put a vacum on the tank then pull a plug out on the lower front of the engine. Then put a niple on with shot shot of hose and then take vacum off and out comes the coolant in to buckets. I now use that line for a cabin heater so it has a valve on it to shut off in summer.
Good luck.
Good luck.
1976 FBC
3208 NA
3208 NA
Thanks.
Will try that. Sounds like a nice and clean way to remove the coolant.
Users browsing this forum: Google [Bot] and 42 guests
