Hull number
Hull number
Where can I find the hull number on my 46'6" SF? Where did Bertram usually put these?
Re: Hull number
1972 on it should be on the transom. Pre 72 they could have put it anywhere. Try looking at the transome under the deck. I found numbers thee, others have found them up in the berth area.
Good hunting.
Good hunting.
Re: Hull number
A friend who had a 1969(?) 46 says the hull number is "top right corner of stern as looking from the rear forward."
Re: Hull number
I could not find mine in all the normal places, but I did find the number 664 written inside my port engine cover when I re-installed the engine sound insulation. It was just written on the inside on the fiberglass with a black marker. I believe that numbers seems correct for a 1968 hull. I also found the date 7/7/68 written after the first hull layup from inside with a black marker while sanding my hull last year. Does anyone know if #664 would appear to be a chronologically correct number for a boat that was built during July 1968?
Craig
2003 17 Cape Horn
Craig
2003 17 Cape Horn
Re: Hull number
http://bertram31.com/newbb/viewtopic.ph ... ers#p61036" onclick="window.open(this.href);return false;
See if this helps.
See if this helps.
Users browsing this forum: Bing [Bot], Google [Bot] and 47 guests
