tooth count on 6bta
- Russ Pagels
tooth count on 6bta
Hey, any one know the tooth count on the fly wheel of a cummins 6bta 250 hp. info need for tach set up. thanks Russ
1972 31 FBC 315-141-1226
is that good men do nothing.
Re: tooth count on 6bta
Is it from the north or the south? If it's from the south it may only have a couple...
I just now looked it up in the parts manual for that engine on marine diesel.com. According to that document there are 159 teeth on the flywheel. See attached. This is for the marine engine. The document is called "Cummins - 6BTA 5.9 - Parts Catalog (B250 Inline) - Engine Configuration: D403028MX02 (CPL 1322) - Bulletin No. 3884392-00 3/91".Hey, any one know the tooth count on the fly wheel of a cummins 6bta 250 hp. info need for tach set up. thanks Russ
- Russ Pagels
Thanks Navatech,that was what I was looking for. I will join boatdiesel.con...Russ
Always welcome Russ.Russ Pagels wrote:Thanks Navatech
Well worth the effort and modest expense IMHO. And, as mentioned previously, I have no interest in that web site other then being a satisfied user as well as an occasional contributor (in a very distant past I was a naval as well as maritime grease monkey).Russ Pagels wrote:I will join boatdiesel.com
Users browsing this forum: No registered users and 52 guests
