oil again
- Russ Pagels
oil again
Hey, one more question.what is the oil capacity of the Cummins 6BTA 250 engine. ya I know I have to get the engine manual...Thanks Russ
1972 31 FBC 315-141-1226
is that good men do nothing.
Re: oil again
Russ, you could join the http://boatdiesel.com/ site and for a very modest sum (25.00 US$) you can download all imaginable manuals for your engine, gear and generator (if you have one). You can also get real professional advice regarding marine diesel engines. There are quite a few real life mechanics there. Ooops... I meant to say technicians rather then mechanics :-)I know I have to get the engine manual...
Disclaimer: I have no connection to that site other then that I'm a satisfied user (and very occasional contributor).
Re: oil again
Russ
My recon 270's hold 13 quartes on each side. The 250's mhave to be close to that.
- Russ Pagels
Re: oil again
Thanks every one ,I have my 7 gal of oil and filters. Now I just need it to stop raining, and get warm enough so the oil pours. thanks Russ
Re: oil again
Navatech wrote: Russ, you could join the http://boatdiesel.com/ site and for a very modest sum (25.00 US$) you can download all imaginable manuals for your engine, gear and generator (if you have one). You can also get real professional advice regarding marine diesel engines. There are quite a few real life mechanics there. Ooops... I meant to say technicians rather then mechanics :-)
You need a lesson on Internet manners and how not to insult very good people especially being new to the site and having no idea the back ground of people here.
Re: oil again
Seeing as you have no idea about my background let me fill you in:You need a lesson on Internet manners and how not to insult very good people especially being new to the site and having no idea the back ground of people here.
- I have been on internet forums like this one since the mid 90's. I know what's acceptable. A little light banter is acceptable most places.
- I myself was of those "mechanics" (or "technicians" if you prefer that term) - I happen to refer to my past as "grease monkey". I have no problem with any of those monickers. As have none of my former colleagues that I know personally. In fact, many of them find this upward creeping "professional terminology" quite ludicrous.
- I have no idea what you mean by "insult".
Re: oil again
I'll spell it out.
"You can also get real professional advice regarding marine diesel engines. There are quite a few real life mechanics there. "
The use of the words "real" and "professional" indicate you feel the advice given here is anything but.
Whether or not you want to use the term grease monkey, mechanic or technician with a smiley face has no bearing on your comment.
Nothing wrong with mentioning boat diesel. Many here are members there also.
Just don't do it by blanket insulting the integrity of the people here.
Re: oil again
Thank you.I'll spell it out.
If I had used quotes then you might have a case. As it is, you're merely interpreting what I wrote as an insult. IOW, the "insult" isn't in what I actually wrote but rather in how you, subjectively, interpreted it. FYI, there was no insult and certainly none was intended. Forums such as this one are textual and therefore open to misinterpretation (seeing as they lack the subtleties of RL P2P communication such as body language and facial expressions). My practice is to interpret posts literally (rather then try and deduct hidden meanings). It's also my practice to give people the benefit of doubt. Especially considering the fact that not everybody has English as their first language.The use of the words "real" and "professional" indicate you feel the advice given here is anything but.
FWIW, if I truly thought that the people here have no real knowledge why would I ask questions regarding my own boat here?
Frankly, how you, subjectively, interpreted my comment has no bearing on what I actually posted. To wit, the fact that I believed, wrongly, that it was the little mechanic/technician joke that got you rattled. I guess I made the same error (assuming non existent facts) that you made.Whether or not you want to use the term grease monkey, mechanic or technician with a smiley face has no bearing on your comment.
That "insult" exists only within your head. And, once more, if I doubted the integrity of people here I wouldn't be here. Be that as it may be, I think it's clear that this mini fracas is a simple misunderstanding and I suggest that we let bygones be bygones. Water under the bridge so to speak.Just don't do it by blanket insulting the integrity of the people here.
Re: oil again
Yup, let it rest...and I suggest that we let bygones be bygones. Water under the bridge so to speak.
Re: oil again
And herein lies the problem with forums, text messages, and emails. Intent sometimes gets lost or mis-interpreted when reading someone else's post.
Regards,
Doug L.
Doug L.
Re: oil again
I believe this is a good time to re-post what good ole' Capt. Pat wrote in the old Swap and Sell Board describing the people that post and are part of this site....I cannot find it.
Re: oil again
Capt. Pat:
LOL....that doesn't happen very often, but this time I don't have an idea in how to get that post back.
Re: oil again
David,
Could you be thinking about:
If so, that ones under the "Politics" announcement... And, yup, it applies to all sections of the forum group.
Third, you have to be respectful of the other members that frequent this section of the forums. We are a family here, often refered to as the "Faithful". We have over a decade of history based on friendship and respect for one another.
Re: oil again
That's what I'm writing about!.....shame on me, I should have figured: POLITICS!
Re: oil again
We need the leader of the Mean Team to set us all straight.
As the Capt. said time to lighten up guys. That has always separated this board from a lot of the others.
Re: oil again
You're all big boys......just take it outside. There's no room for fighting here.
As long as we all wind up singing kumbaya around the campfire after a long day of fishing, it's all good.
Users browsing this forum: Bing [Bot] and 499 guests
