Used Generator
Capt.Frank
Used Generator
Post by Capt.Frank »
Guys looking for any advise. Going to look at a used nexgen 3.5kw this week. I know these Kabota engines are realy simple. Is there anything in particula to check besides running and power output. There is no sound incloser.
1976 FBC
3208 NA
Capt.Frank
Re: Used Generator
Is a sound encloser needed for a low rpm generator? I know most are running enclosers.
1976 FBC
3208 NA
mike ohlstein
Re: Used Generator
Post by mike ohlstein »
My NexGen 3.5 isn't a low rpm model. It's a bit noisy, but not too bad. With the enclosure, it's fairly quiet. I wouldn't say that it's necessary, but it helps some. The down side to the enclosure is that it requires a fan to draw air through it, and the fan isn't quiet either......
Mean Team Leader
PREDATOR
Burn Oil
Eat Food
1973 FBC 1286 0273-315
wmachovina
Re: Used Generator
Post by wmachovina »
Mike, I use one of my old gasser blowers for the fan fits and works great,can't hear it over the rumble
Bill
Joe E
Re: Used Generator
Post by Joe E »
Capt frank, if you pass on the gen set, can you send the info my way, I am looking for one as we speak(write) Joe
Keith Poe
Re: Used Generator
Post by Keith Poe »
Only good thing i have found with the cheap loud gens is the noise draws predators in unlike chumming being one direction sound is 360
Video Link
Monster
http://www.facebook.com/photo.php?v=610 ... =3&theater" onclick="window.open(this.href);return false;
jrhaszard
Re: Used Generator
Post by jrhaszard »
I have a Mastervolt 3.5 with a single cylinder Kubota diesel and it is very noisy. Located OB of Port Engine. Mostly exhaust noise.
BERG1847M80F
Keith Poe
Re: Used Generator
Post by Keith Poe »
on the bow of the gray boat is a black BBQ cover about ten bucks at Lowe's and under it is a 3.5 KW Gasser electric start cost was about 250.00 or 350.00 and has a remote for my key chain.
This one has been on the bow for 4 years still working and the one before it none electric start was there for over ten years still working put away in my garage.
I just uncover it when i get where I'm going and turn it on and off with the remote on my key chain when i get hooked up.
There are two 1500 watt halogens on the arch with dimmers on each light.
buzzk
Re: Used Generator
Post by buzzk »
My last boat had a Next Gen 3.5 KW. It was great. Never had a problem. It was a little noisy but I didn't have a sound shield.
Users browsing this forum: Carl, Google [Bot] and 6 guests
