Cockpit Side Panels
Cockpit Side Panels
Gentelmen-
I have pulled the cockpit side panels out as part of some winter projects. They are vinyl covered and have been painted gray.
I am considering stripping the vinyl (more lik helping it fall off...) and fairing/painting. I am concerned that I will need to cover with a layer of glass or at least veil to get a good outcome.
On the "someday" list is removing them all together - boxing the cap and fairing the inside of the hull. But, for now, what do you recommend?
Stephan
Stephan
Re: Cockpit Side Panels
Stephan,
Seconded on Formica or silimar hard laminate. Use epoxy to laminate for exterior use. The edges can radiused and be glassed over wtih a couple of layers of epoxy and veil. Hard laminate readily takes paint after a good sanding and primer coat of 545.
- MarkS
Patrick are you getting any time in on that hammock? :)
Looks like my toe hold idea caught on.....
Naw, Mark. I've probably laid in it 10 times for a total of 5 minutes...MarkS wrote:Patrick are you getting any time in on that hammock? :)
Thanks Mike, I couldn't remember where I came up with that idea...mike ohlstein wrote:Looks like my toe hold idea caught on.....
Thank you gentlemen.
Not wishing to try anyone's patience... here's what I will do:
- I will sand the striped plywood and coat with unthickened epoxy to pretreat the wood.
- Laminate Formica on to boards with West System (straight epoxy or with some cabosil?).
- Trim up edges with laminate trimmer and seal end-grain of the boards with thickened epoxy.
- Sand laminate with 60 grit paper
- Prime. Prime. Sand 220 grit paper. Prime with 545.
- Paint. Scuff. Paint with Interlux Brightside Polyurethane
Use enough Cabosil to make a mix the consistancy of mayonaise...- Laminate Formica on to boards with West System (straight epoxy or with some cabosil?).
Use a round over bit to avoid 90 deg corners. Use a couple of layers of veil. Epoxy by itseft will shrink and crack down the road...
This is excellent guidance. Thank you very much!
Stephan
Stephan
Please excuse my ignorance, but what is "veil"?
BRUISER
BERG1552M76F-315
Bradley Tiller
BERG1552M76F-315
Bradley Tiller
Capt. Patrick, in the pics above with the new hatch and side panel/door, is that a Glass Tech deck? If so what did you do to "convert" it?
BRUISER
BERG1552M76F-315
Bradley Tiller
BERG1552M76F-315
Bradley Tiller
bbtiller wrote:Please excuse my ignorance, but what is "veil"?
Yup, Glasstech... Cut out the space between the two hatches and reconfigured the drain race.bbtiller wrote:Capt. Patrick, in the pics above with the new hatch and side panel/door, is that a Glass Tech deck? If so what did you do to "convert" it?
Capt Pat, Did you make those removable fishboxes? Like more details on those if you did. Stephan, no such thing as a dumb question here...thats how you learn my friend..BH
A lot of "as you go" changes were made to the initial concept drawings to end up with the real life production. I started with a plug mold from a pervious fishbox I did for Jay Smith. I enlarged the width to fit the Glasstech deck, re-gelcoated the mold and went from there...
I know that you, (and probably a few others), like the long story from a graphic standpoint, so here ya' go:
http://www.bertram31.com/hancock/img/cockpit/fishboxes/" onclick="window.open(this.href);return false;
Capt Pat, You make it look so easy...a removable fishbox is on my list...after I get her floating... some times you get stuck thinking in one direction..your detail sure helps get over and round those hurdles..where do you get your fiberglass extrusions? McNichols or McMaster Carr? Thanks for sharing that..BH
Truly amazing capt. Pat what are you using to secure you decks down. I noticed you filled the screw holes. Did you expoy the screws in? Joe
Holy crap what a link!CaptPatrick wrote: http://www.bertram31.com/hancock/img/cockpit/fishboxes/
I have never seen that link before................Capt. Pat, you are a dang Rock and Roll Star! The amount of work and attention to detail is incomparable.
All from McMaster Carr...Bob H. wrote:where do you get your fiberglass extrusions? McNichols or McMaster Carr? Thanks for sharing that..BH
The center section of the deck has flanges on both sides, so the center is screwed down first. The out board sections are positioned and screwed down with three screws to the outboard joists. The inboard screws are set from below, angling up to the underside of the deck, then a latex caulk is run down the joint line. Only the out board screws need to be caulked over.Joe E wrote:Truly amazing capt. Pat what are you using to secure you decks down. I noticed you filled the screw holes. Did you expoy the screws in? Joe
The original screw holes were epoxied over... Not only were those two rows of exposed screws butt ugly, but also every one of them was just a way for water intrusion to the deck core.
Capt. Pat
Did you close up the space between the outboard edge of the deck and the hull? If you keep the cockpit panels and leave that open, I find that something always finds a way of droping down in that space. A real pain.
Tony,
The pink stuff along the out board side of the deck, in the image above is Awlfair over an 1/8" of glass atop the outboard deck joist and faired to the hull. It becomes the outboard water race directed to the scuppers.
Amazing work.
Capt, thanks for providing that info.The center section of the deck has flanges on both sides, so the center is screwed down first. The out board sections are positioned and screwed down with three screws to the outboard joists. The inboard screws are set from below, angling up to the underside of the deck, then a latex caulk is run down the joint line. Only the out board screws need to be caulked over.
you must have done the same to the "Classic" after the replacement shaft pad work.
i now know to look for the screws up underneath, instead of drilling out the epoxy and not finding anything.
eric
Eric Vincent
1974 31 FBC hull # 315-1442
Capt. Pat, how did you fair the glass tech deck?
BRUISER
BERG1552M76F-315
Bradley Tiller
BERG1552M76F-315
Bradley Tiller
- Junior Member
Patrick, where does the water go from the hatch drain tubes? Bilge, or have you devised something else? My fiberglass deck and drain trays were all molded as one piece and the drain tubes just went into the bilge. Is there a better way?
Leo,
Water does go to the bilge, but all drains are hose directed to the center aft bilge, never dripping down on equipment or other unwanted spots...
I piped all of mine together and took them out the transom along with the drain from my on deck fishbox. It was tough getting fall, but they seem to work pretty well. I have to tie my boat out away from electricity during hurricanes and I wanted to keep as much water as possible out of the bilge. I also tape all of the deck seams during a hurricane.
CaptPatrick wrote:Tony,
Was wondering what the best way of handling that was. Thank You
Re: Cockpit Side Panels - Again and some more
Gentlemen-
Thanks to you for the guidance above which I have finally put to good use.
The cockpit panels had been covered with a thick marine vinyl that was glued and stapled to the plywood panels. Getting the vinyl off was easy but the glue was tenacious and soft. Any attempt at sanding it off immediately clogged the sand paper. I ended up using an IR heater to really soften the glue and then a sharp pull scraper.
After this the panels could be sanded.
I collected everything heavy I had around and laid out the panels, gooped em' up and laid on the Formica.
Despite your clear instructions I did manage to make a mistake.
Though I used copious amounts of epoxy/cabosil and notched spreader I managed to have a big void.
I fashoned a pastry bag out of a ZipLoc freezer bag and squeezed more epoxy/cabosil into the void while the panel was stood on end to get some help from gravity.
Then I pressed it hard for 12+ hours.
The other panels came out reasonably well and I have faired the the seams where two pieces of Formica met.
I have purchased Interlux Pre-Kote and Brightside realizing I am giving up some of the paint quality for the ease of a single part primer and paint to work with.
Any thoughts on how to avoid voids in the future are very welcome as is instruction on the painting phase.
Many thanks and best,
S
S
I like the toe boards! Does the stranded veil cloth wet out better than a light weight cloth? I hate working with the tight weave as I get bu-cu little piss-ant sized air bubbles trapped under the tight weave that is in a std cloth.
Well, having fixed the void in the lamination of the panel there was a small ridge at the edge of the void. I'm not sure if this is a result of sliding some adhesive in the original lay-up or overfilling in the re-lamination. The ridge became apparent in long boarding out the primer.
We'll see if this prints through significantly into the finish. What I have learned is that the Formica has saved tons of time from faring the panels and I think yield an end product that is lighter too.
Best,
S
Best,
S
Maybe this input is too late, but I made some nice side panels out of Azek. You can buy panels. Bang it and the color is the same all the way thru. I used white about 3/8 or 1/2 in thick( can 't remember).
Giff
Gif-
Thanks for this.
Azek would have been better as I am discovering the amount of time I'm spending priming-sanding-priming-sanding-painting-sanding-painting-sanding-painting... I may just scratch these in my garage to get the first one out of the way.
Best,
Stephan
Thanks for this.
Best,
Stephan
Users browsing this forum: Bing [Bot], Google [Bot] and 589 guests
