Bertram B26/26 photos
I would like to see owner photos of any b26/26's out there.
Check out the photo gallery at http://www.25Bertram.com
I'm pretty sure the reason there are not too many pics of '26's is because they didn't make all that many of them.
There were some built around mid '70's, like mine and Chile's, and then there was a different production run later (mid 80's?) which was a slightly different boat.
The later version as far as I know was the only factory Bertram with outboards....although I believe that those were also available with inboard power.
Also run a google search for "Caribbean 26" which is a version of the Bertram 26 made under license in Australia. I believe that this particular model has now been modified slightly from the original in order to accomodate a different power package once the inline sixes were no longer available.
And here is a link to Chile's project pages including an article on the 26:
http://ccridlin.home.mindspring.com
I am considering upgrading from current 23' walkaround as I don't like bumping elbows. I want a trailerable boat and the Bertram 26 convertible's with 10' beam appeal to me. I like the express style, simple fishing layout, and Bertram class. I wanted to see a few existing users boats to see how they outfit them.
At the risk of offending 26 owners....go with the 25. Hundreds to choose from, 10ft beam as well, original Ray Hunt design hull, parts and information much easier to come by, available in I/O or inboards, and as you mentioned; "trailerable"
This is of course unless you run across a deal on a 26 that is just too good to pass up.
For some reason I was under the assumtion that the 25 was 8 or 8-6 beam. Also someone had told me that the Hunt hulls were a bit of a wet ride - but what do I know. I am definitely not opposed to 25', just want the beam.
This is why I came to this Bertram site, I was told I would get good advice from Bertram owners with knowledgable opinions - thanks!
Ditto the 10' beam, I have a citation from the overwide police to prove it.......I had the first Another Joy, a 1972 B25 hardtop with i/o for 17 years before I beacme the Steward of the "new" B31 AJ in the early 90's. The B25 is without a doubt the best bargain in a boat that size on the market. No, not wet, the big bow flare knocks it down real well. In the engine department, for i/o, go with the Mercruiser 3.0 liter 135 hp four cyl. Some of the discounters in FL still sell the complete package, engine, Alpha One outdireve, all the install stuff, brand new with a factory warranty, for under 6K. Da Judge has them in his B25 and they are fast and diesel-like efficeint. I put Vulva 4 banger turbo diesels in my B25 (after the original Merc 6's froze and cracked blocks) in 1984 at a huge (at the time) cost. I caught over 100 marlin on that old B25. Would not do the diesel again on them, too heavy, but shoot, bet I ran 5,000 hours with just the usual Green Motor problems, like all the shit falling off them.........
The B25 is the best buy by far for a "real" Bertram. One of the Faithful, Kelly Small of P'cola, FL sent me some pix of the tower he has just put on his B25 (a FB inboard) and it is about the slickest pocket rocket boat you ever saw. Go for it.
Well, you know I would have to chime in sooner or later.
I love my B26 and it has even more bow flair then the 25 (so I have been told). I have also been told by the guy that runs my marina that people always stop and stare when they walk by her. There are only two things missing... A generator and AC.
That being said... I'm looking hard at a 1978 Bertram 33 that is gas powered and in near perfect condition. Is it time to upgrade and start a diesel repower project?
Chiles
Chiles
I love my '26. The room in the house is a bit more than the 25 and it suits the way I use my boat.
That being said I think if I were interested in a Moppie (or convertable) I'd seriously consider the 25. I like the tumblehome at the transom and the elliptical shape of the transom as well. I think David Napier gave up those wonderful Ray Hunt esthetics in order to pull the hull from a one piece mold. More efficent production, but at the cost of some of the roundness and lovlieness of the original 25.
Then again there is the possibility of one of the later '26 factory outboard models. They have their own charm and strong points. Particularly for a trailer boat.
In each case the boats are just over trailer max...they actually rate as wide loads, but mostly it is close enough you can get away with it, especially if you are not going far.
The best part is that with any of them the boat will take all that you can throw at it. If you are going to be around blue water, Bertram is the way to go.
Chiles, Did you know that R.P.M.'s original parent company (R.P.I) was developing a Wankel that ran on Diesel for the milatary about the time that the marine guys split off? What do you think? A Diesel rotary project?
Just kidding about that,..... but not about RPI's Diesel Wankel.
- thuddddddd
stuff
Stew, the reasong they stop and stare, is so they don't trip while trying to figure just who whould have designed that buttt ugly boat, and how come it doesn't have a sea ray tag on it
Thudddddd
Chilles started it
Thudddddd
Chilles started it
Thudddd,
I had a Sea Ray once. I made money on it too. bought it, repaired the engine and sold the engine for more then I paid for the boat.
I made the guy take the boat as part of the deal. Too bad I can't do that with your Hatteras. The engines are useless you have a need for a pony sized oil squirt can. You have demolished the top half of your boat so the way I figure it, you are 50 percent done.
Hell, the only thing more crazy then reparing the tubbb is buying a second set of oil slinging dump truck engines.... oh; sorry.
Chiles
Timmy really did start this one
Chiles
- thuddddddd
stuff
did the guy with the 2 rusted out hundyi's you got your motors out of make you take them also?? or is that what your using as morrings? thats what I'm going to with my old DD's
Timmy, don't let these guys deter you from your foolish, but creative rebuild of the Tubb of Guano. You have always impressed me as a guy who has ideas that are real good, but just miserably fails in executing them. But, on the other hand, I hear your dog sucks getting birds. Not all of us can be good at everything, just live with it.
Yo Fren'
Yo Fren'
Have you checked out Chiles' link? What about boattrader.com or other online listings??? There's quite a few out there... Here are links to a few:
http://adcache.boattraderonline.com/6/7/3/84451873.htm
http://www.boats.com/listing/boat_detai ... ew%3Dfalse
http://adcache.boattraderonline.com/6/4/2/1524942.htm
The Hard top listed is actually a 25. I have noticed over the years that lots of sellers identify their 25's as a 26. Now that would be someone that has absolutely no idea what they own. It is however an exceptionally clean 25.
- thuddddddd
stuff
Thanks UV, for the words of encoragement. you be the bestest.
thudddddddddddddddddd
- Terry Frank
- Hyena Love
B26
Its the second best smaller hull produced by Bertram. We call it the puppy hyena.
Chiles,
Looking good, had a friend that owned a B26 FBC with inboards before his exwife took it in the divorce back in the early 80's.
Then later he was the Charter Captain on the B31 which I now own after the owners let it get repo back to the bank. Then called me to go make my deal for it in 1986 and the rest is history. Been lovin-it ever since.
R,
DQ
R,
DQ
Another one...
Here's my 26 at my dock before I removed the radar mount. I don't have too many pictures of her (because I'm usually in her looking out!)
Cheers!
![Image](http://idisk.mac.com/jep111-Public/Angel3atDock2.jpg)
Cheers!
- Capt. Mike Holmes
26 Bert
I fished on a friend's 26, and was on a much larger boat in a rough water tournament when his 26 passed us both going out and coming in with no problems. Really rode the seas nicely. Very nice looking boat, and just a bit bigger than the 25. He chartered his for many years.
Users browsing this forum: Bing [Bot], Google [Bot] and 376 guests
