You called Randall, who eyeballed it for 8 seconds and cut the boards with a grapefruit spoon?Bob H. wrote:Guess how I cut those sweet miters on the radiused corners? BH
Tip Top Teak only......what do the Bertarm brothers recommend I use?
I personally don't like side exhaust... But if you do go that way, make solid flares on the forward half to deflect water flow when in forward gear at less than planning speed. Water flowing directly over an un-flaired, (flush), side exhaust port can create significant back pressure...What are your thoughts on side exhaust with or with out surge tubes? seems to be a point of debate.
