I'm trying to stay ahead of the curve being prepared for a marine survey for insurance.
What requirements will i need to meet for 1977 diesel motors as far as fumes blowers etc. ?
Got the rudders, SS bearings, 304 rudder bar and all the steering components installed today and toed out the rudders to 7/8".
Think i'm going to use U bolts to install the hydraulic arm plate to the rudder bar to mack it up and test the strength and see if it's strong enough.
I'm not so sure i want to weld it just yet till i get the auto pilot and supports installed then maybe if it is not strong enough with the U bolts.
Marine Survey Blower Motor Ventilation Systems
Re: Marine Survey Blower Motor Ventilation Systems
No fume blowers required for diesel....What requirements will i need to meet for 1977 diesel motors as far as fumes blowers etc. ?
Keith,
There are not any requirements for blowers in a diesel application, if your present blowers are in place and are working I would leave them in the boat, the scoops can provide extra air flow into the engine box and help to remove heat build-up from the boxes. Air flow for diesel is a major factor in good performance of the engines.
Pete Fallon AMS
Pete Fallon AMS
Thank you gentlemen
Users browsing this forum: Bing [Bot], Google [Bot] and 31 guests
