Mold Release Remover?
scot
Post by scot »
I use multiple layers of paste wax on molds/plugs, etc. as a mold release agent. What is a good solvent to get the wax off of the finished piece? Something that is stocked at the local hardware store would be best for me, I'm ready to do some glass work and really don't want to order a speciality solvent if I can avoid it...xylene? acetone?
Scot,
Naptha is a good wax remover & should be available from either a good hardware store or paint supply chain. Follow up with warm soapy water & rinse.
CMP
Post by CMP »
If your hardware store doesn't carry it, your local Sherwin WIlliams store does...
CMP
scot
Post by scot »
Thanks guy's, we have a Sherwin Williams. That's typically where I find my toxins & various other nasty VOC's.
Capt. Mike Holmes
Naphtha
Post by Capt. Mike Holmes »
Scott, naphtha - and the "extra" h is the correct spelling, as my ex-boss kept impressing on me - is what most charcoal lighter is. Cheaper probably to buy it that way that as a speciality chemical.
randall
Post by randall »
works great for cleaning old wax off surfboards......should remove mold wax no sweat
Capt. Mike Holmes
Removing ....
Randall, especially if you light it!!
randall
Post by randall »
well its not as flamable as acetone
scot
Post by scot »
I like it, That way if there is any left over from the mold clean up I can keep it around for startin' up the grill.
randall
Post by randall »
all kidding aside...when you pour high flash liquids like acetone they leave a vapor trail back to the container...which is also flamable....the flame will travel back and ignite the original container if it still has any liquid in it....not fun if you are still holding it................voice of experience..............................recently at the gas station this fella is filling gas cans while smoking a cigar......says "its ok....i'm a fireman"
This works as an alternative fuse if you run out of primer cord, or so I've heard. :)
CMP
Post by CMP »
One thing to keep in mind when using this stuff is that you gotta do a slightly different version of the old Mr. Miyagi-Wipe on, wipe offotherwise, you'll leave residue behind...
CMP
Users browsing this forum: Bing [Bot], Google [Bot], Oldcreek and 51 guests
