While the deck is off I am down to little stuff. Exhaust, steering, fuel lines, and a little wiring. Not a lot left to get the deck on and gt her moving again.
Guess I should make a list of my questions and ask them once and not create n posts. But anyway. Her are 2 more
1. What size cylinder do I use on the steering? At this time I am probably going to get a set up by uflex because I can get it wholesale. Unless anyone has had problems with them.
2. What is best place to tie in the water supply hose on the dripless shaft seals? I have the pss
Hydraulic cylinder / dripless shaft seals
Matt
Hull #315 - 854
Matt
Hull #315 - 854
Re: Hydraulic cylinder / dripless shaft seals
I took my water out of the bottom of the Sendure.
Matt
I just replaced my steering cylinder.....I am guessing that the cylinder diameter is about 1-1/2 to 1-3/4 inch OD. I can measure the old one tomorrow or whenever if you need me to do so.
I chose to hook up my shaft seal water supply directly to the back of the raw water pump.....no real reason.....just felt like it was a good place.
Kinda looking for part number on cylender so i know what actual size to get
Matt
Hull #315 - 854
Matt
Hull #315 - 854
- Capt.Frank
I replaced my a couple of years ago with a K-19 (hynatic) telflex
1976 FBC
3208 NA
3208 NA
Users browsing this forum: No registered users and 123 guests
