ZF Tranny Fluid
- conchy joe
ZF Tranny Fluid
Since I can't access the old BB, I have to ask what the group recommends for ZF 220 tranny fluid. I already have all the specs from ZF, but bottom line what products are you guys using that I can run out to the auto parts store and get without having to translate all the specifications.
Also oils which can be used in both the tranny and engine (Cummins 4BT)?
Thanks.
Thanks.
Troy & Daria
Hypoluxo Point, FL
Hypoluxo Point, FL
Re: ZF Tranny Fluid
I use straight 30wt pennzoil in the trans... Valvoline blue 15w40 in the cummins...
'79 Bertram 31' Sedan
Re: ZF Tranny Fluid
Hey John is the boat in the water yet?
Re: ZF Tranny Fluid
Gonna be spring Pete, broken foot put me out of commission the beginning of the summer... Engines are in, up and running perfect...
Re: ZF Tranny Fluid
sorry to steal your thread troy!
John last time I was in OYC I saw summerwind but not the sedan, where is she? Would love to come check out your progress...
Pete
Pete
Re: ZF Tranny Fluid
She's at my house... Switched them out so I don't have to drive 45 min to go work on her... Shoot me a pm I'm usually around...
Re: ZF Tranny Fluid
Troy, I am not at all an expert, but you are not getting too many answers, so I will weigh in. 15W40 is the oil used in most diesel engines and it has detergent properties that keeps soot from building up in a motor, but causes foaming in gears, so people use a straight viscosity oil like 30 weight in the gears. Both types of oil are readily available in auto parts stores.
Re: ZF Tranny Fluid
Troy, I run shell rotella 15-40 in all my heavy equipment and trucks, the gears got rotella straight 30. BH
Users browsing this forum: No registered users and 276 guests
