5200 Shelf Life
5200 Shelf Life
Not sure if you guys know this but if you put the opened tube in a plastic bag remove the air and toss it in the freezer it will last a very long time.
I use one over a year.
I have taken oil and water based paint tools brushes rollers etc. and tossed them in plastic bag and in a bucket of water sealing out the air with good results and believe this could also work with 5200.
Re: 5200 Shelf Life
Good tip, Keith...
Another technique, that I use, is to remove the nozzle, clean it out good, insert a 1/4" bolt or #12 screw into the tube tip and wrap it with tape before tossing it into the fridge. I have an office sized fridge, set at about 40ºF just for chemicals.
Another tip, if you do fiberglass, is to wash out the "throw away brushes" with the proper solvent, (acetone for polyester/vinylester or denatured alcohol for epoxy), and then store the brushes in a sealed container of the proper solvent. I've got "throw away brushes" that are over 5 years old. Same for rollers...
Re: 5200 Shelf Life
5200 lasts forever. I just cut a hole in a soft spot of the tube when I need some......
Re: 5200 Shelf Life
Yeah this works great.mike ohlstein wrote:5200 lasts forever. I just cut a hole in a soft spot of the tube when I need some......
...but tossing tube back into tool draw for the next time always seems to make a mess.
However, the up side to that is it's a real good way to keep your tools together :)
Re: 5200 Shelf Life
I don't need those feeler gauges any more anyway....
Re: 5200 Shelf Life
ROFLI don't need those feeler gauges any more anyway....
Using 5200 drives me crazy because of the way it gets all over everything and continues to ooze from the tube even if you take the pressure off the caulk gun.
My use is generally in smaller amounts. I NEVER cut the tip off the nozzle. I unscrew it and set it aside. Then I squish a little 5200 onto a scrap of wood or carboard and work it from there with whatever stick, screwdriver or putty knife is appropriate. The nozzle screws back on as a cap as soon as I am done dispensing about what I need. This keeps the ooze factor down so I don't find myself dripping it on the floor and walking through it tracking it everwhere, or inadvertently putting my hands in it and getting it all over the work or my tools. Clean up the tools you do use and any on you fingers or workpiece with denatured alcohol which is cheaper and handier than acetone or other more aggressive solvents. My tubes of 5200 last a couple of years like this. And I don't waste gobs of it to the ooze factor. They also sell 5200 in smaller tubes that aren't made for caulk guns, but if I don't use the whole tube on one job those clog up on me and become useless, so I still buy the caulk gun version
I find large wire nuts work pretty well for various caulk tube caps.
Re: 5200 Shelf Life
mike ohlstein wrote:I don't need those feeler gauges any more anyway....
At least you can get yours out of the draw...
Re: 5200 Shelf Life
5200 also has a aluminum seal on the bottom of the tub for caulking guns.
Re: 5200 Shelf Life
CaptPatrick wrote:Good tip, Keith...
Thank you Patrick i'll be putting that to good use.
Re: 5200 Shelf Life
One other trick and it works for types of caulk and sealant, it to take liquid tape or plasti dip and seal the tip with it. Just dip it in or paint it on. Peals right off the next time you need to use it.
Users browsing this forum: Google [Bot] and 49 guests
