I have a pair of Volvo Penta TAMD41P 200 HP engines in a 29' Phoenix. My starter is rated at 3kW at 12 VDC. So, I think that translate to an amp requirement of:
A = W/V = 3000/12 = 250 A
When I account for a round trip length about 20 feet from battery plus to switch to starter plus and from the starter back to the battery negative AND allowing for a 3% loss, I am coming up with 2/0 wire required.
What wire size would you recommend?
Can you guys tell me if I did this right? Sorry to ask a question on here about a Phoenix but my boat sort of looks like a Bertram 28 so I hope you guys will forgive me. But, having a heck of a time figuring out what battery cable size I need. Thanks. Joe Z
Help with Battery Cable Sizing
JoeZ,
When you replace the cables have the ends put on with a professional crimping tool or have the ends soldered on and heat shrink the cable ends. Make sure that the posts on the battery switches are cleaned good, I've seen too many new cables wasted because the battery switch is completely green. 2/0 is OK but I would rather see 1/0 on runs over 20 feet.
Users browsing this forum: Bing [Bot], Google [Bot] and 18 guests
