Fuel lines?
Rickysa
Fuel lines?
Post by Rickysa »
When redoing the fuel system on this DD project, using the new fuel filter caps/bases means the original steel fuel lines no longer fit. Before I take on another challenge (getting proficient at bending 3/8 steel tubing), I thought I'd run it by here to see if there are any other options?
Ricky, just go with approved marine fuel hose...
Ricky, Go with the blue marine fuel lines, with push on ends, no bending at all, cut to fit, drop of oil on fiitting, push in until yellow cap bottoms out. Parker makes some great products, I had a ton of connections not a single leak, primed the system and the engines jumped to life..BH
bob lico
Post by bob lico »
It don't get better then that -------- picture book with raccors in the hole.
wmachovina
Post by wmachovina »
Bob, I used the same blue lines w the push on fittings, perfect, just wonder if hey are commercial approved, a friend has a 41 Viking and needs to replace his lines and the blue Parker w fittings is a better price , he's just concerned about it passing a survey, mine passed no problem.
Bill
Whaler1777
Post by Whaler1777 »
They are uscg with the series 26 fittings...
'79 Bertram 31' Sedan
Capt.Frank
Post by Capt.Frank »
Bob that is a work of art!!! and that is the bilge. Awsome work.
1976 FBC
3208 NA
Rickysa
Post by Rickysa »
Great info folks....many thanks! (so much better than what I was looking at re: bender etc.)
on to the wiring now.....
JohnCranston
Post by JohnCranston »
Good info,Gentlemen.
Where's the best place to buy the blue lines and the Parker fittings?
Many thanks.
John.
Hyena Love
Post by Hyena Love »
Wilco Supply - Houston.
Whaler1777
I used maesco in nj
Brian Y
Post by Brian Y »
I just bought 40' of this material and multiple fittings from John Bowen, at Elite Diesel, in Clear Lake. Joe, in the parts department gave me wholesale prices. You may want to check them-out, if you are nearby.
Users browsing this forum: Bing [Bot] and 387 guests
