Anybody have a few of the small lights that fit the original Cummins VDO oil pressure, temprature gages......that you wanna sell.
or
Know where to buy them???
Its about time to buckle DeNada's control/instrument panel and I need a few of the "Gage Lights"
Instrument Lights
Stop the presses....I just found a box with s bunch of old original Cummins VDO gsuges, three of which have lights installed.....the lights are tiny and are in a strange little plastic holder that presses into the back of the gauge....each with two spade connectors for the light. I'll test the lights in a little while and let you know.
How many do you need?
Okay - I have two clear ones and one red one that work. But I'll want to keep a couple for AJ so I'll look up the Cummins part #s for you & I'm sure Cummins Mid South has them.
Do you need the bulb holder too or just the bulb? Two of my three blubs didn't work at first until I removed the bulb from the holder, shot some CX in them, scraped the corrosion off the base of the bulb, etc.....so if your have bulbs & they don't work, take an ohm meter and test them - a good bulb will show continuity.
Here is your source for the bulbs, cheap. You need the Type A metal base bulb, 7 mm. I measured my bulbs with a mike and mine are the 7mm.
http://www.jegs.com/p/VDO/VDO-Gauge-Acc ... tgod320NXg
Users browsing this forum: pschauss and 292 guests
