water pump capacity?
would anyone care to guess the gph capacity of the raw water pump at normal 120v rpms in a nextgen 3.5? Thanks Bill
Bill
BERG1474M74J-315
BERG1474M74J-315
I ran my 5KW Northern Lights on a 5 gallon bucket and it emptied the bucket in very short order......like less than a minute.
I'm gonna guess that your pump has a 3/4" suction hose......and will pump about 500/700 gallons per hour......I'm also guessing that the genset runs at 1800 RPM.
I don't think it matters much what kind of Genset it is or what kind of engine it is......mostly the pump size and RPM.
from the looks of the output seems to be much less than a 2000 gph although it is hard to tell because of the larger discharge size and the discharge location at the water line.
harry - i will check the output size in a day or two when i am at the boat (i think its an inch or an inch and 1/4
i am having to re-route this intake because of a tight corner from the original installation so it would be a good time to put in a valve and a pickup for an additional emergency pump. just dont think it is worth the effort for less than 1000 gph.
Bill
BERG1474M74J-315
BERG1474M74J-315
Users browsing this forum: No registered users and 34 guests
