Awlgrip flattening agent?
Anyone have any first hand recommendations as to what can be used as a substitute for Awlgrip's flattening agent?
Without compromising the 'integrity' of the Awlgrip paint.....
I cannot get Awlgrip's flattening agent off the shelf locally.
I'd like to tone down the gloss finish of the Awlgrip paint I'm going to use for re-painting the non-skid on the deck of my flybridge if I can use a substitute.
Sanding is not an option as I will be applying the non skid particles [Awlgrip's Griptex] same time as the paint.
Preston Burrows
1976 B28 FBC
BERF1398M76J-285
1976 B28 FBC
BERF1398M76J-285
Awlgrip G3013Q, 1010 Flatting Agent for Topcoat-Qt is available from numerous online sources... (Google search)
Amen - on another boat I used the flattening agent on nonskid - just the nonskid. It was harder to clean up and it stained. I ended up doing it over with the regular glossRaybo Marine NY wrote:gloss paint will reflect heat, repel dirt, and be easier to clean then a flatter finish. I would really think it over if that gloss bothers you or not.
Gents:
Thanks for the replies and happy christmas to you all.
Bertramp: I have Awlgrip already in hand.....and Interlux's flattening agent is not sold off the shelf here either....if it was I wonder if it would be compatible with Awlgrip?
Capt Pat; cheers, to get a quart to me here in Nassau would cost a couple of hundred bucks between freight/hazmat/duty charges for which it's not that important.
Raybo; good points.....and no the gloss won't bother me,especially if it's cheaper...so I'll go with what I have....I was hoping someone would have an old painters trick that would have me saying ddddduuuuuhhhhh why didn't I know that!
Pleasant holidays to you.
Preston Burrows
1976 B28 FBC
BERF1398M76J-285
1976 B28 FBC
BERF1398M76J-285
Nothing like the sweet smell of Awlgrip in the morning!
This morning I applied the first coat of Awlgrip with the Griptex non-skid particles,tomorrow,weather permitting, I shall apply a second coat of paint only......thanks again to those who offered advice to me of this!
![Image](http://i242.photobucket.com/albums/ff253/prestonburrows/Boat/FlybridgedeckAwlgripnon-skidpaintingfirstcoat271211005.jpg)
Preston Burrows
1976 B28 FBC
BERF1398M76J-285
1976 B28 FBC
BERF1398M76J-285
Raybo:
Cheers, I'm seriously thinking at what a 'cheap' air compressor and spray gun etc would cost me so I can spray Awlgrip..........those side panels on the flybridge are looking in need of paint now that the deck is glossy....... and would be good training.....
Plus I'd rather spend the prep time masking off and suiting/gearing up than having panic attacks when I realize I only have 2 hands to roll,tip,spread Griptex etc.
Needed a helper yesterday......the boat was rocking in the slip like the B28 it is and it was fairly warm with full sun so I had to work fast........
Preston Burrows
1976 B28 FBC
BERF1398M76J-285
1976 B28 FBC
BERF1398M76J-285
spraying Awgrip - not a good idea - it has some real nasty chemicals that disperse in aerosol. Not for the ill equipped.
Harry: Cheers, Alexseal is not available here....basic supplies of Awlgrip and Interlux products are,......and yes I would take the panels off and paint them on the horizontal on the hard.
JeremyD:No worries, I have access to / use of respiratory safety gear and if I did spray would not compromise myself without.
Rolled on the second/final coat of Awlgrip only today, the results are reassuring to my feet and pleasing enough to the eye!
Someone walking the dock asked me if it's possible to tint the Awlgrip base colours....I know you can mix different Awlgrip base colours together as you wish.....but don't know if you can take Awlgrip in to a paint store and have it tinted just so?
Don't know about dock walkers and some of the questions asked, but it got me wondering is all!
Preston Burrows
1976 B28 FBC
BERF1398M76J-285
1976 B28 FBC
BERF1398M76J-285
Users browsing this forum: No registered users and 254 guests
