I know, sounds like a stupid question. Let me explain...I bought a custom Starboard tackle box that fits into my helm, and found out that it's not bright white, but has a yellow tint to it. I didn't know about the wrong color untill it was installed. The box is great as it allows you to drop open the front door, which enables you to either grab individual Plano boxes, or, open up the door fully, and allowing total access to the wiring on the inside of the helm. If there's a way to prime and paint the Starboard without the paint coming right off, then, I'd like to go that route instead of having another box built.
Any help on this one would be a great help.
Thank you.
John.
painting starboard
- JohnCranston
painting starboard
As far as I know you can't paint Starboard. In fact it is almost impossible to glue Starboard, although I do have two adhesive systems that you can glue it with, but they are difficult to use because they are both two part systems and have a "pot life" of about 15 seconds.
- Skipper Dick
- JohnCranston
Walter,
We pretty much figured that it would come down to that, but, always looking for an easier solution.
Frank,
The overall dimensions are about 23" x 26" from what I can remember. The frame work is glued together, kind of like a picture frame, but, if I bought a big enough piece of Starboard, then it should handle the frame and cover of the box.
Dick,
Well, the proof is in the pudding...it won't work.
Many thanks, fellas
John.
Frank,
Dick,
Many thanks, fellas
John.
Users browsing this forum: No registered users and 238 guests
