Rocker Stoppers(?)
Rocker Stoppers(?)
I'm sure most here are familiar with the B28's unfortunate propensity to roll when not under power. Has anyone tried out Rocker Stoppers? I hate to fork out 60 or 80 bucks for them, plus storage space, without some assurance that they work.
"you do have the drunk rails still?"
I do, though I've been tempted to remove them to open up the cockpit. The problem is worst when we anchor and chum on a busy weekend. Even though we may be seated three or four across the stern every boat wake sends us sliding back and forth across the cockpit. And queasiness is liable to follow for some.
Preston, your suggestion sounds like a good one for drift fishing.
UV's right, the further out the better and the further down the better.
The deeper they go, the heavier the column of water they have to resist.
I've heard that in real sloppy seas, the rapid motion does not give the cones enough time to settle to work properly and they end up working half ass.
Make your own out of 5 gal buckets.
Take 3 buckets, you can always add more.
Drill a 3/8 hole in the center bottom of all three.
Run a 3/8 line thru the hole on the buckets and leave a loop to attach a 10lb weight under the last bucket.
Every 4 or 5 feet knot above and below the hole in the bucket bottom and then around the handles.
Becareful to not hang the weight on the handle. The handle is only to keep the buckets upright.
Leave your self enough line to experiment with depth.
Flopper stoppers
All right Bruce, your one of the smartest guys on the board, and I'm sure I'll regret this, but I'm going to have to disagree with ya on this one. First, I think the flopper stoppers work against the resistance thru water, not the weight of the water column, unless you lifting them out of the water. Second, a bucket will have about the same resistance going up or down hanging from the sides so will not be very effective. Granted, the rope will be taught on the rise and slack on the fall (slower down) which will work to some extent. I believe flopper stoppers have little water resistance on the fall, and high restance on the rise, as long as the surface is not broken, depth shouldn't matter. Like I said, I'm sure I'll regret this, but at least I think I'm right.
Scott
Scott
Rocker stoppers
I have a bunch of traffic cones in the garage, they would probably work.
Scott,
Your 100% correct if the floppers have some sort of flap check like the old par pumps. They will work much better than the buckets.
Having never seen the floppers I don't know how they are made only that two people in the past have tried them and both said the results were not what they expected and seemed to get worse the rougher the seas got.
Both individuals were fairly bright boaters and I assumed they were deployed correctly.
One tried the bucket theory I passed on and reported it worked to some extent and worked better the deeper they were lowered.
I figured it was the resistance of the column of water they were trying to move.
Buckets are certainly not a replacement for a well designed and deployed anti roll system.
Hmmmm.......deeper means more weight on the flopper, so harder to pull up. I'm no engineer, wanted to be one, but the math kicked my butt in the early 60's so I opted for law school where reason is thrown to the winds.
I remember a college physics class where the prof was explaining that a huge bridge pier exerts as much force down as it holds up.
Let's imagine a 50 foot diameter disc suspended below the boat, say one on each side, with a rope thru the middle of each disc attached to the outriggers on each side. I challenge any of you engineers to explain to me why one of the discs that is suspended deeper will not exert more drag on the rope than one near the surface, even if the shallow one never breaks water. Sure, the friction in the water is most of it, but as Bruce says, the water column is heavier on the deeper one.
Eagerly awaiting an answer......
Gismo's of this nature work based on diameter, or resistance. Not the weight of the water. Water column is measured in PSI, not linear weight as relates to gravity. Every 33 ft the PSI doubles. Atmospheric pressure is 14.7 PSI, at 33 ft the pressure is 14.7 PSI, 66 ft= 29.4 PSI and so on. That's why 33 ft is commonly refered to as (1) atmosphere. This works out to roughly .5 PSI per ft. i.e. 200 ft of water has a pressure of approximatley 100 PSI.
With that noted, the "weight" or force pressing on the bottom IS based on depth.
The reason they do not relate to depth is that the water is pushed out of the way to the sides as the disc rises. If the disc were sealed in a pipe like a piston the column weight of the water WOULD apply.
I believe this applies assuming the depth of both is deep enough for the surface not to be capable of relieving the movement of the water. Say all disc being deeper than 10ft or so. If one disc is 2 ft deep and the other is 50ft deep there would be a difference because the surface can relieve some of the reaction of the shallower disc.
So your all correct, but for the wrong reason. Deeper works better.
My .02 cents
My .02 cents
No, ya'll still dodging the issue of water weighs more than air. If the disc is inside a PVC pipe, won't the deeper the disc is make it harder to move?
I may be dumb, but after hauling the Bride's pot plants in before the freeze last nite, I can tell you water weighs more than air. My back tells me that too.......
Scot,
I have to differ with you slightly on the pressure debate. Every 33 feet the pressure is increased by one atmosphere. On the surface we are experiencing 14.7 PSI which is one atmosphere. At 33 feet the pressure is 29.4 (which is doubled) but... at 66 feet the pressure is 44.1 (increased by only 1 more atmosphere) and at 99 feet the pressure is 58.8 etc.
Its my opinion that these "Rocker Stoppers" work based on resistance only and that weight and pressure do not even enter into the equation.
I think that this is one of those conversations thats only solveable with a bottle of Crown and a Patio Fire on a cool brisk evening.
Harry Babb
Harry Babb
Flopper Stoppers
Think about this, if water depth increased lifting resistance, your anchor would be almost impossible to pull up in deep water, and would get eaiser as it came up, and ya know that ain't so.
ScottD
ScottD
You are correct. My brides pots that are full of water weight more than the ones full of air also.
We got-ta-get the pipe out of the discussion...it appears to be confussing the hydraulic logic.
The krux of it is that the weight of the water is also appling itself (in PSI)to the bottom of the disc as well...it's an even pressure, therefore it cancels out additional downward force on the disc.
Density of the water, not weight makes them work. Getting them deep removes two elements; surface reaction and wave action. Got-a get'um down past the waves.
You must be a lawyer, I can't put up much of a defense agin mamma's flower pots. LOL
Now, putting them farther from the boat on out riggers makes perfect sense. That creates leverage and the stabilizing force of the disc is multipled at the boat.
Try to hold one of mamma's full flower pots with your arms fully extended.
Harry,
At 33 ft water weights 14.7 PSIG, or "Pounds Square Inch Gauge" thats because ALL the instruments that we use are calibrated to remove the 14.7 atmosphereic pressure and read "0" at the surface. You are talking about PSIA, I was speaking of PSIG.
All of your statements are true, I'll take Jim Beam please....but I'm running on memory and didn't bother to break out the calculator, or clarify correctly.
Chiles
OK, now time for the Virgina boy to add his .02 cents.
I believe it is all drag. The design of the device appears to allow for less drag on fall, and more drag on being pulled.
Think about it this way, when you have a streatch 30 on your trolling rig, does it pull harder when it is at depth then it does when it is only 5 feet from the surface? It may slightly because of the drag of the line thru the water, but I don't think the depth itself causes it increase drag.
Planes fly high because the air is less dense, and less dense means less drag and they can fly faster. Water does not change in density and has the same density at the surface as it does at 200 feet. Water can exert pressure, but can not be compressed (unless it is heated to steam, but that is another conversation).
Therefore it is the opinion of this slightly educated red neck that only the drag created by the top of the design of the device that makes for the friction needed to slow the roll of the boat. I also concur that the bucket would work similarly, and maybe not need to be the full 5 gallon, but somewhat less.
Let the criticism begin.
Chiles
Chiles
UV....well i often explain to people that the water isnt the wave....the wave...a huge and powerful band of energy moving through the ocean (originally wind energy....and before that solar energy)..makes the water do that......same concept.........i think.....btw...after i left you folks at dinner i walked the wrong way cause i was blabing with caren on the cell phone.....i surely would have missed my bus but i realized my mistake in front of a taxi depot............................luck counts......was great to see you
Well, How about this?
The oncoming wave exerts a force on the side of the boat which causes the boat to move. If the boat were tied too tightly to a dock, the lines would be forced to obsorb that energy and transfer it to the pilings.
The rocker stoppers are deployed and energy is transferred from the boat, thru the line to the stoppers which in turn use their coefficient of drag to transfer that energy to the water. The more surface area of the device, the more drag can be transferred. The further the divice is away from the boat, the more fulcrum effect would be exerted.
I've given some further thought to the depth question. Assuming the water less turbulent at depth, the drag would be greatest when the water is still. At or near the surface, wave action will make the water turbulent and reduce the drag that is exerted on the device. Therefore, I would believe that more depth would preferred.
Chiles
(Not enough to do at work today)
Chiles
Haven't been around for a while but I got to add the following
Rockers stoppers work on the principle of drag thru the water, no question on that.
The longer the moment arm, the better they will work cause roll is a torque applied about the boats center of gravity, and the T= (Force) X (Length of the moment arm from the center of gravity)
So for a given torque ....... F=T/Moment arm
Since the torque is constant, varying the moment arm or force can counteract the torque and keep it from causing roll.
Longer moment arm equals smaller force to counteract the Torque.
By extending the depth, you are essentially increasing the moment arm.
My 2 cents.
My 2 cents.
- TailhookTom
Don't forget to have your cutting torch on board so when those birds start swinging through the air, you can climb the outriggers and cut the chains free while pitching about in 30 foot seas.
Okay, so that was The Perfect Storm -- I guess you could get away with a fillet knife!
TailhookTom -- now I know why they say I am Physically challenged
I don't know if those little orange cone things will work or not, but I had the same problem with that roly-poly tossyourassouttathetower 28 footer Xanadu. Instead of tossing the cash out for the rocker stoppers, I figured an even better way.
Check out the avatar for a sure fire way to end the hyena from rocking and leave momma's plants on the porch.
- TailhookTom
Randall: One would certainly think so -- especially considering most of those boats are backyard engineered one offs. Something comes to mind -- batten down the hatches!
Hey, on a completely different issue, did anyone see the report of a 77" Bluefin tuna taken in Bogue Sound in only 3' of water on a spinning rod. My understanding is that the fish was put into a 15 Carolina Skiff and was greeted at the dock by various government officials who wanted to see the tuna permit. The operator showed his permit, which was actually for his 25 Parker -- at seeing the frown on the Confiscators faces, he supposedly said, "I thought it was a yellowfin, not a bluefin!" Sorry Charlie! Reminds me of a couple of years ago with the fiasco up here where surfcasters were catching School Bluefins right off the beach on Block Island -- can't land them, cause you can't get a land permit!
Anyhow, I digressed, something about 3 hours of sleep the past 2 nights and numerous pots of coffee.
Tom
Tom
Okay guys.........I am at the bottom of that bottle of Crown.......Have we made a decision yet???? The original question is is it worth the 80 bucks???
My decision is NO......spend the 80 bucks on enough gasoline to get your ass out of that sloppy crap........go home and change the oil or something...
Its been fun
I enjoyed this post and the following threads
Harry Babb
Its been fun
Harry Babb
Ok after reading all the theory's I have a question. I understand drag is drag and water weight is water weight. But if we lowered a rocker stopper down 5 feet and used a scale to somehow measure the pull at that depth, then tried it at 30 feet, it would stand to reason the scale should show two differant pulling weights due to:
a) the differance in the drag of the water, or
b) the weight of the water, or
c) the pressure of the water, or
d) the denisty of the water.
and of course one of you is going to say all of the above.
What am I missing here? Tony Meola
OK I will finally pipe in on this one being a lowly Aerospace Engineer. To cover Tony’s question, the pull would be identical, except due to the difference in the weight of the rope like UV pointed out, however since some line floats… it would be less.
Water is essentially incompressible and the density is the same if you discount the salinity difference, which at these surface depths is identical. A gallon of water weights the same at 50 feet as it does at 5 feet.
Drag = ½ * (Coefficient of Drag) * (Density) *(Velocity)^2 * (Surface Area)
That’s it. The coefficient of Drag for what ever will not change, the surface area did not change, assume the velocity is the same, and the density is the same. The amount of pressure does not matter, because water is incompressible.
Do you really think it is harder for a fish to swim at 50 feet than near the surface? Does the hydraulic hose get heavier on the high pressure side when you turn the wheel?
Scott
Scott
Scott Traenkle
Rocker Stoppers have been on the market for years, so they must do something. I say buy a half dozen of them from Worst Marine, string them up and try them. If they don't work well enough, return them after Christmas as an unwanted gift. (Staying away from the science and going straight to the R & D) I did see a variation of these things somewhere that was two aluminum plates with a hinge between them. It collapsed on the down stroke to be streamlined and opened up to a wide vee on the up stroke. A small weight was used to collapse and pull it down. It would seem they would store away easier. If you try the Rocker Stoppers, let us know if they work. I anchor out a lot and the roll is a pain.
Eddy G.
Eddy G.
- thuddddddd
Scott,
Being the engineer.....
We know a fish, like a sub is built streamlined. Going horizontal thru the water makes no difference at depth unless your at the surface as a sub goes faster submerged.
But the stoppers are not going horizontal or streamlined.
They are designed with a surface area to catch the water and slow or prevent the boat from rocking by the resistance of moving the water that is above them out of the way.
While some of that water will move to the sides, some wants to come vertical or lift up depending on the vertical speed of an object.
Tie a rope in the center of a 4x4 sheet of ply and submerge 10' then pull straight up, some water will move off to the sides, how much will depend on speed, the rest will resemble a dome on the surface right before the ply comes out of the water.
Now take into consideration the weight of the rope for deeper depths, would it not require more force to verticaly raise that ply the lower you go because of the water above it and having to move it out of the way?
Or does that water weight only come into play at the surface?
- thuddddddd
stuff
Scott, don't know about a aerospace enginer(or how to spell it) but I agree with you about being lowly.
The rest of you , wern't you proud I was able to make 2 pages??
Santa better be real nice to me, maybe one of those cool mid atlantic shirts, or the oak bluffs one, (running out of UVI bilge rags) maybe even one of the Mt gay rum ones, nah I like those.
Let's say I put a one ton (2,000 lbs for you engineeringly challenged, like Timmy) weight on one side of the boat off a rope, and a two pound weight on the other side. Both suspended the same distance below the surface on identical ropes. Both have the same vertical cross section, imagine a sash weight a foot long, the onther a few hundred feet long, but the same cross section, the heavy one just a verrrry long sash wieght.
Which one gonna put the most resistance to rocking the boat?
Huh???? C'on you engineers, come out of your techno holes and give an honest answer. This is important......
UV, Esq.
UV, Esq.
- Terry Frank
Users browsing this forum: Bing [Bot], Google [Bot] and 58 guests
