I slid my shafts back to add the PSS shaft seals, do i need to replace my original solid couplings, or should i reuse them. Also the orginial set screws were drilled,i have not been able to find any, have them drilled or go with out safty wire??
thanks
Shaft couplings
Shaft couplings
Matt
Hull #315 - 854
Matt
Hull #315 - 854
Matt
Reusing the propeller shaft coupling is perfectly acceptable.........as long as they still fit properly.
The coupling should have a "Bump Fit" on the shaft.
I have seen many of the coupling without safety wire.....and many that did have the safety wire.....and the wire not installed properly.
Its not a big deal to drill them yourself with vise and a hand drill....or even Vise Grips and a hand drill......I would say do it.
I'm also using the PSS shaft seals on DeNada.....really looking forward to a dry bildge.
Users browsing this forum: Bing [Bot] and 277 guests
