I'm trying to remove my hard (wire reinforced) rubber exhaust hoses to repair and paint the area underneath during winter layup. Getting the hose clamps off was easy but the hose seems fused to both the engine flange and the outlet flange.
Any thoughts on how to loosen these pups up and slide 'em off without destroying?
At $20/ft for new ones I'm not excited about just cutting them!
Thanks in advance for any suggestions
Exhaust hose removal help
- Skipper Dick
There is a tool I've seen mechanics use to get under hoses that you might ask about in a Auto supply store. It has a solid handle like a good screwdriver but the end of the shaft is like flattened icepick that has been bent to a right angle. They work the end under the tubing and then work it around the flange to loosen the hose. It's not a flimsy tool as it sometimes gets a lot of stresss. Yours is probably "cooked" on from all the heat. Walter
I just removed mine last week and used a hack saw blade with duct tape wrapped around one end to make a handle. Work it in between the fitting and hose to separate the two. I had a muffler connection that I had been trying to get loose for nearly 30 minutes and the yard guy came over with his magic tool that Walter described. He got it loose and the other two I had not gotten to yet in about five minutes. If you can find it, get the tool!!!! Eddy G.
Users browsing this forum: Bing [Bot], Google [Bot] and 58 guests
