blacked redfish?
- JohnCranston
blacked redfish?
I've got the skillet, blackening powder and butter, question is, what next? You guys fixed me up with the seared tuna, can you help me out here? I'm trying to broaden my horizons without setting myself on fire.
Many thanks.
John.
Many thanks.
John.
Heat the skillet to about 600 degrees (your laser heat gun will help here), butter up the fish filets, sprinkle the blackening powder on, then slap it in the skillet for about 90 seconds per side. Keep a big pot lid handy to cover the skillet and put out the fire before it catches the ceiling.
A much better way to do redfish is "on the half shell"....filet and leave the skin & scales on, make a sauce of lemon, butter, & garlic and place the filets scales down on a hot grill and baste wiht the sauce. Cook until the fish is flaky.
- JohnCranston
Thanks, UV and Walter,
I mis-spelled blackened, sorry. We do the fish quite a bit on the half shell, and were wanting to try something different. Thanks for the advice.
I just need a good recipe for kingfish and I'll have all bases covered.
Thanks again,'
John.
Thanks again,'
John.
walter you caught me by surprise with that comment (keep scales on) 65 years i never was aware of that as a matter of fact i always insist my son remove the skin while he fillets the fish like fluke,stripe bass , sea bass,porky. you leave it on while cooking then peel it off before serving i assume.
Bob- I only leave the skin/scales on if I am going to do the fish on the grille. The fish doesn't stick then and you can easily move and lift a whole fillet off the grille with a spatula. If I do a big fillet, I score the flesh at portion sized pieces almost down to the skin and put a wedge of lemon and onion into each cut. Big fillets need 2 spatulas or a real long one, to lift the fillet on to a serving dish. At this stage, the skin is so charred, a simple cut with the spatula edge separates the portions. I usually serve each portion with the lemon wedge and half onion ring I had previously inserted. The cooked flesh just comes off the charred skin on your plate as you eat with a fork. The charred skin sometimes adds a bit of flavor that enhances the dish.
- JohnCranston
For blackened fish I only use a Heavy Cast Iron Pan...really makes a difference as it holds alot of heat. I avoid covering to keep from steaming..I like my Blackened Crust...well for a lack of better terms "Crusty"
Also a real good exhaust fan is a must...or you have to do what I do...cook Blackened Fish and Steaks on the BBQ side burner.
I haven't tried buttering up the fish before hitting with my Blackening mix...usually I just Dry Fish and liberally rub seasoning into the meat/fish.
Small dab of butter in the pan and put meat/fish directly over and give up to a minute depending on cut, flip to a hot portion and give another bit of time till you ave a nice crust then onto the plate...with pan off heat add a nice glob of butter to pan, scrapping any of the spiced fond into a sauce and drizzle around plate.
Spice mix...haven't found one on the market yet that is not too salty...I usually toss my own together... equal-ish parts of all the spices you like. For me, its Fresh Black Pepper, Garlic & Onion Powder, Hot Paprika, Cayenne, Oregano and Basil plus a portion of Kosher Salt.
- TailhookTom
- JohnCranston
Users browsing this forum: Bing [Bot], Google [Bot], Tommy and 216 guests
