As most of you know I am rebuilding "Phoenix", and while the cockpit sole panel is off the boat I decided this was a good time to see why the generator would not start.. while doing that I found that the little raw water pump was frozen and would not turn. Removed the pump and disassembled it.. needed new bearings.
The pump was sold and installed in a boat in the US..
The generator was assembled in Italy (Mase)..
The single cylinder diesel engine that drives the generator was made in Japan (Yanmar)..
The raw water pump on the engine was made in Sweden (Johnson)..
And the bearings I had to replace in the pump were made in France (SKF)
It really is a small world
Footnote:
Sadly.. NOTHING WAS MADE IN THE US!
It really is a small world...
Re: It really is a small world...
IRGuy wrote:As most of you know I am rebuilding "Phoenix", and while the cockpit sole panel is off the boat I decided this was a good time to see why the generator would not start.. while doing that I found that the little raw water pump was frozen and would not turn. Removed the pump and disassembled it.. needed new bearings.
Footnote:
That which holds everything was...the boat.
Users browsing this forum: Carl and 30 guests
