Barrier to antifouling..Is hard tie coat necassary??
tunawish
Post by tunawish »
I know this has been beat like a dead horse but put so much time and now $600.00 in paint into this, I want to get it right...
3-4 coats of Interprotect 2000
3 coats Micron extra..
I've heard the Capt and others recommend a hard non ablative tie coat before the Micron.
What is main reason...?? Is it only for a permanent wear indicator with anti fouling properties..?
Any harm in going right to the Micron after last barrier coat tacks up..??
Ray
In Memory Walter K
Post by In Memory Walter K »
As I understand it, a first coat of a different color lets you know when the Micron extra has worn down to the point of needing retouching or repainting. My guess is that the hard coated ablative keeps giving you antifouling protection until you apply more Micron Extra.
captbone
Post by captbone »
I went two years of hard over the barrier coat before I went ablative.
I just wanted something to protect the barrier coat as I do wear off the ablative from beaching and running over jetskiers.
I would not want just ablative over barrier coat after all of the work.
tunawish
Post by tunawish »
Doesn't the hard coat loose it's affectiveness after a year anyway..??
captbone
Post by captbone »
At the end of the year when I haul, the ablative is all but gone. No growth on the old bottom paint. I am sure it looses some of its protection over time but its still better then nothing.
I didnt stager the colors, I have black hard paint under the black ablative.
tunawish
Post by tunawish »
captbone wrote:At the end of the year when I haul, the ablative is all but gone. No growth on the old bottom paint. I am sure it looses some of its protection over time but its still better then nothing.
I plan on 3 coats of ablative, I've gotten about a full season for each coat before I need to paint on another 3....
Especially with my seasons being shorter than they were before..
bob lico
Post by bob lico »
ray i don`t have answers all i can tell you is the capt. definitely has a point.i took phoenix down to gel coat and applied 4 coats of interprotect. i even remove jack stands and use wax paper so every coat covered the complete bottom moving stands 4 times and repainting every 12 hours , a real pain in the a-s . i did not use a hard tie coat of bottom paint and went to the ablative micron extra. black over white interprotect. every year i pull it out i get one or two areas the the hold 4 coats of interprotect flake off in addition to micron usually a 3" rounded area and always in a different place perhaps i should have heeded the words of the capt. now i live with it. every year sanding out the area to 6" and reapplying interprotect and micron. on the subject the Prop speed application did nothing for speed but keeps the ss shaft , rudders and nibral props clean.
captbone
Post by captbone »
I also alternated between the white and grey interprotect. It helped me get the best coverage without missing and will also let me know if there is any problem and at what level it goes to.
Previous Discussion http://bertram31.com/newbb/viewtopic.ph ... ght=#17722
The hard bottom paint does two things:
1. Acts as an effective antifouling last protection layer before the barrier coat shows through, but won't slough off.
2. By using a clearly different color than your choice of visable bottom paint, the color acts as an indicator, siginaling time to repaint.
By using a hard bottom paint as the first coat over the barrier coats, you'll have plenty of time to schedule maintenance coats before you're down to the barrier coat.
The barrier coats have no antifouling qualities what so ever and should never be allowed to be exposed to marine growth, (and subsequent sanding).
Remember, you CAN apply ablative paint over hard paint, but CANNOT apply hard paint over ablative. It will just flake off...
JP Dalik
Post by JP Dalik »
Regardless of what you used the interprotect should not be coming off. Maybe to much wax paper.
We just did a short haul after the full bottom job,
sandblast
interprotect 3 coats
bottom paint- all ablative one tie coat 2 build
results
no chips no dents no scratches
2.0 kts improved at low cruise 2200 25.3 kts loaded
1.2 kts top end improved
Not bad for the heavy girl she is. One day I'll find a magical propeller.
tunawish
Post by tunawish »
CaptPatrick wrote:Previous Discussion http://bertram31.com/newbb/viewtopic.ph ... ght=#17722
Thanks Capt Pat...So it basically protects the barrier coat from having to be sanded if it's ever exposed....
At the suggestions of many here, I'll be alternating white and grey barrier coats so I don't miss anything and be using the step back procedure at the jack stands Giff suggested...
And if you'll use a different color for the hard paint, it'll let you know when to repaint.
Unless red is your finish color, use it as your hard coat...
When shifting jack stands and keel blocks when painting, use butcher paper, (shiny side up), rather than wax paper. Butcher paper is plastic coated and won't transfer the release like wax might.
Keel blocks can be easily moved around by using a 12 ton bottle jack. Only jack up just enough to move the block and never move jacks alone. Always have someone around as a spotter...
Below is the correct way to orient & stack concrete blocks
While these small boats only need 4 well placed jack stands, when painting it's safer to use at least one additional stand so that the load is never out of a four point balance.
Marlin
Barrier coat
Post by Marlin »
Capt, what an eye for detail, a real mason
bob lico
Post by bob lico »
jp i used the wax paper over the stands so it would not stick to the paint as i shifted the stands around after each coat of barrier coat did you do all three coats and then deal with the spots under the jack stands and blocks?how are you dealing with growth on shaft,rudders,props?
JP Dalik
Post by JP Dalik »
Morning Bob,
We just moved the jack stands between each coat. In the spots where the blocks were they had to be done seperate, it just added some time no big deal.
As far as props rudders and shafts they all have prop speed on them, this is our 4th season using the product and it works well, just remember not to hit it with the pressure washer (it gets kinda fuzzy) on the last short haul I just wiped it all down with a rag.
Users browsing this forum: Bing [Bot], Google [Bot] and 106 guests
