Shinnecock Sharking Advice
Hey guys was planning on taking out my boat to go sharking on the fly tomorrow. As it turns out I'm not all that comfortable that the boat is running good enough to make the run without worry. Another story.
In any case my buddy that I am making the trip with just moved his boat, 23 regulator out to new Suffolk and hasn't done an offshore trip through shinnecock yet. Looking at the sea gull chart the Coimbra seems to be the nearest most popular sharking area.
I'm thinking of bagging the trip on my boat and heading out of shinnecock on his boat any suggestions with 25 miles or so besides the Coimbra
40"23.2
72"21.5
40"23.2
72"21.5
If you're fly fishing, you want the 30-80 lb ones that will put on a show for you and are landable for tagging. Unlike Blue Sharks, I have found the Makos dart in and out of the slick rather than lazily swim through it. Our trick is to prep some hookless Mackerel as teasers. Put one out about 30-50 ft from the boat but completely visible to you. One person is assigned to that conventional rod and reel. Once a mako appears (he may even fake you out and blind hit it when you're not looking, leaving with a taste), you reel what's left slowly in. If he rushes for it, yank it out of the water completely and cast the fly behind the fish and strip. What usually happens is the fish is now searching for what he bit, sees the moving fly and hits it going away. If they're around, you'll need a few mackerel. The original bait and switch. Don't even bother with the Blue Sharks as you'll be on one for a lot of valuable fishing time. They'll roll when running and screw up your expensive fly lines on their sandpaper skin. In fact, given that distance casting is not necessary here, use your older lines for this kind of tackle abusive fishing. Your 20 lb tippet will break before your line will. Good luck!
- TailhookTom
Users browsing this forum: Bing [Bot], Google [Bot] and 65 guests
