2011 Project Finished - Salon Door -
The door frame was rotted - I remade in teak - as well as painting the door with awlgrip and refinishing the wood.
Hopefully it won't leak like it was leaking during Florida thunderstorm season...
Thanks - it was quite a bit of work fitting to the door frame. Not quite level or square.
I used awlgrip - sanded down the formica down to 220 grit.
filled in any dents with epoxy and microballons -
Had to use some epoxy and clamps to reattach the formica some of the wood on the door had separated - I also repainted the covering boards the same way when I first got the boat - they came out well.
closer look
Yeah - sort of works like that, doesn't it?Eddy G wrote:That really came out nice. If I paint the rear bulkhead and door, then the cockpit panels will look crappy. Then if I paint the cockpit panels the ..........
Nice clean looking B28 you have there.
Eddy G.
Users browsing this forum: Bing [Bot], Google [Bot] and 279 guests
