Back Window
Back Window
When we hit the sand bar, my buddy slid into the back window and did a number on it. As per Uncle Vic's suggestion,we are planning on having a local glass dealer replace the glass. My brother went back down yesterday and could not remove the frame. He said he removed the screws on the top half of the frame thinking it would have a front and back piece, but he said it looked like it was one piece and was unable to pry it out. He did not remove the screws from the bottom half of the frame, so I was thinking that maybe the bottom half might have a front and back piece so it could be removed, allowing removal of the upper half of the frame. Anyone have experience removing the back window frame? Here is a picture of the broken window:
Thanks again for the help,
JR
JR
JR,
They look like the same ones on my 28. When I took mine out it did require a bit of muscle since they were siliconed in. They will flex quite a bit but when you install them again and put the screws back in they are fine. They are two seperate peices so you sandwich the glass between the frames during re-installation. I do not recall any hidden screws. Should just be the ones you see in your photo.
Jack
They are two pieces. An inside piece and outside. It has been a while, but if I remember right I might have used a putty knife to break the seal. Now, since you don't know what they put it back in with, you might want to try spraying some debond around the outside frame to let it soften up whatever is there.
Slide the one window open if you can just make sure there are no screws in the track.
It has been a while since I did mine, but they had some really hard snot around them. Also it seems to me that you need to take top and bottom out at the same time. Be careful with the little plastic slide piece that goes into the aluminum channel for the glass to slide on. I could not find a replacement. American Marine sold me the felt. A dead blow hammer helps in removing them. I primed and Awlgripped the frames white while I had them out.
Thanks for the reply's on the window. When I bought the boat, after some research and a few emails to Capt. Patrick, we came to the conclusion that this boat started life as a sportfisherman model, and the back bulkhead and windows were added later. I guess there is a chance the back windows are different than the stock windows that came on the flybridge model. My brother is a mechanical engineer, so if there was an easy way to get it out, he probably would have gotten it on the first try. I guess there is also a chance that there is some glue or calking involved. To bad there is not some way to remove the glass without removing the frame. We're going to go down tomorrow and give it another shot.
JR
JR
Jack,
Those are stock windows.
The are set in with bedding compound, and they will not release easily.
They may have screws that do go straight down as well, down in the channel. I don't remember.
And the little bit about your bro being a mechanical engineer? Forgive me, but that will only qualify him to ###### it up, and over complicate it. Just my experience with engineers. Like lawyers... ;)
Good luck with the window. They come out hard. Don't worry about needing to pry the hell out of them, but don't bend the extrusion. Its a fine line...
When removing my side windows I found that a putty knife heated with a torch and some wooden wedges worked well. Slide the knife under and replace with a wedge. Work around patiently adding more wedge as you go.
It took a bit of effort, but we ended up getting the back window frame out. It must have been a retro frame because it was a single piece. Most of you guys sound like your back window frames had a front and back piece, but these were set into the bulkhead with a large bead of caulk. The frame and damaged glass are at a local glass dealer for fabrication. We worked around the entire frame with a utility knife and then used Mikey's method with a putty knife to get it to relaese.
Thanks for all of the help,
JR
JR
Mikey,
That's exactly what I was saying when we got the frame out. More like aaaaaaaaaaaAAAAAAAAEEEEEEEEEEEeeeeeee.
Rawleigh, Mine were also two pieces, a top and bottom, but it sounds like some guys had an inside and outside piece. The broken glass and frame are already at C Glass getting fabricated.
aaaaaAAAAAAAAAAAEEEEEEeeeeeee,
JR
JR
Users browsing this forum: Bing [Bot], Google [Bot] and 25 guests
