Fiberglass advice needed
My B20 is in and getting used. I've pretty much decided to keep the foredeck, but to smooth it out--take out the hatch, fill lots of small bolt holes to large glove box and compass holes, and cut out where the instrument panel/helm was. I'm planning on having a single pop-up cleat on the foredeck--that's it.
The f'glass is about 1/4" thick. I've read the instructions about scarfing, etc., and have West epoxy and fillers on hand. I don't know what to use as far as cloth, mat, etc. Also, I have some real thin, maybe 1/4" marine ply. Should I use that to fill in the big stuff, like the hatch, and glass over/under it?
Any suggestions will be greatly appreciated.
These pics. should give an idea of what I need to do.
John - are you planning on painting after or are you going to match gelcoat?
For the screw holes, I attacked with the grinder, dish out really nice and deep. I went about 3/4 of the way through the original laminate thickness. Depending on thickness, keep the scarf pretty shallow so you will have about a 2 inch sized dish.
Wipe clean, cut your glass (i used 1708 for deeper ones or just plain matt if it was shallow) and lay it in. I overfilled every hole and ground / sanded smooth after cure. I was painting so I sanded smooth then Ryan at RCS went over with the Duratec fairing primers, etc.
For the dash cutouts, I would scarf the edges, put some plywood in as core and layup with 1708 same as the smaller holes.
I used Vinlyester throughout and thought it was easier to use than epoxy.
Ian.
Ian.
Rawleigh- The foredeck looks llike 1/4" or so of glass with a 1/4" or so of plywood that's exposed from the underneath.
Ian- Thanks. She's painted now, so she'll be painted. I'm not redoing the boat at this point, I just want to get the foredeck straightened out. Next would be stringers/deck, followed by bottom job/exterior paint. Little bit at a time though.
Sorry for the slow response, was out of pocket until yesterday evening...
First, keep in mind that epoxy has a higher shrinkage rate than polyester or vinylester, plus it takes up to a year for the shrinkage to finally reach a point that it doesn't ghost, (print through), back under the paint.
This is really only an issue when doing high visibility work like you'll be doing...
1708 or 1208 biaxle is a good choice for the larger areas but needs to be buried beneath a couple of layers of chopped strand mat to keep the weave from ghosting back.
Mat can be used with epoxy but it won't completely wet out because the binder that hold the strands together is formulated to dissolve in contact with styrene. (See: West System Epoxy Article on mat)
Make all of your epoxy modifications to stand above the finished surface by 1/8" and allow at least a couple of weeks for the epoxy to shrink down before grinding.
Your initial grinding should bring the modification down to about 1/32" below the finished surface to allow for fairing. The best fairing compound is Awlfair, (also an epoxy) has a very low shrinkage rate, sands easily and further prevents ghosting of the substrate.
Prep for the Awlfair is a sanding with 220 paper and a couple of layers of 545 Awlgrip epoxy primer, sanded with 320 paper. The longer that you can put off fairing the less ghosting you have to deal with. Final fairing shoud be done about a week before top coat painting.
Backing large holes with 1/4" plywood is fine, but try to make the backing larger than the hole so that you won't have ghosting issues from that perspective.
She's not a B31 (sure do miss the Anna E.), but I've started the winter foredeck project on my B20. I've cut out the hatch, helm area, epoxied in marine ply backers and filled alot of holes. No f'glass yet, and I need to figure out where the bulkhead is going. I'll probably move it back to the edge of the foredeck. Gonna' play around with fishing rods and figure it out today hopefully.
John- Having a B-20 Bahia Mar, I have found having a lockable storage area for often used rods and lure boxes, etc. a distinct advantage. What I DID find a pain in the ass was getting to the bow cleat to tie and untie the boat. If you reach it from the cockpit, fine. If not, move it back till you can. Also, easy access to your anchor. Walter
Agree with what Walter said.....Walter K wrote:John- Having a B-20 Bahia Mar, I have found having a lockable storage area for often used rods and lure boxes, etc. a distinct advantage. What I DID find a pain in the ass was getting to the bow cleat to tie and untie the boat. If you reach it from the cockpit, fine. If not, move it back till you can. Also, easy access to your anchor. Walter
Looking good though John...
Ray
O.K. Capt.,
I see how you don't want to skip any major fairing steps in the process
before a non skid would go on, but when you get to the point after it is
shaped properly and smooth, I meant the last steps after primer say,
using the Kiwigrip product. You would still see imperfections show through
with such a heavy thickness?
[url]
http://www.jamestowndistributors.com/us ... ne=adwords
[url]
It'll be a challenge, but I'm hoping that with alot of fairing, I can get the foredeck right. I gave my windshield to John D., but got it back yesterday to make sure that the radius in the foredeck is right. Thanks for the comments.
Rocky,
I've never used, or even seen, the Kiwi Grip, but I hear it's a lot like pickup bed liner material... I'd guess that kind of thickness and texture could hide up to 1/64" of irregularity.
Also, the quicker the transition between irregularities the more visible the irregularity becomes. Vertical surfaces will show irregularities more than horizontal surfaces. Vertical surfaces reflect nearby objects like pilings, water, the boat in the next slip. Horizontal surfaces only reflect the sky and any vertically attached item in the boat, such as an engine box, hand rail, or cleat.
One way to determine fairness is to flood the surface with water. While it's dripping wet, stand back and observe the surface. If you can see unwanted transition areas, fair it some more.
By doing this, you'll be assured that regardless what finish material is used, the surface will be cosmetically pleasing. Once a final finish has been applied, it too late to make corrections...
Yeah Capt. Pat I've seen this on a boat (just walking by) and talked to
the owner a bit he applied it himself, claims there is no "aggregate" or foreign material in the stuff.
It gets it's non skid properties through a special
roller so there is nothing to fall out in time with heavy cleaning. Apparently
there are different textures for different techniques also. (light to heavy).
But I've got to say the glossy deck does look great, that kind of uncluttered
look! Good luck with her John it's looking great so far, I like the center console how it turned out, that was your design right?
Rocky-
I built the console to fit me and the boat. Its narrow enough that I have 20"+ on either side to walkaound it, and the control height and overall height are sized to fit me (5'6")--not too tall.
John, My tip would be to use peel n ply on any wetted out surface, rolls on top of wet poly or epoxy, helps to get air bubbles out making for a better finished surface..early next day peel off and presto top shelf surface for any prime, filler or paint...on Capt pats link to west system the mention it briefly...ask Harry Babb how it works...I wont glass without it..BH
How I've been spending my winter. The foredeck has been glassed and I've just started to fair. We'll see how that goes. Just did the first attempt and a rough sand. I did another coat today, and tomorrow I'll give hand-sand this time and maybe make a long fairing board to try to get where I glassed the hatch right.
I made a new one-piece bulkhaed, installed an access door, and built in some rod storage under the foredeck. There's storage for 8 rods. 6 have to be 6'6" or less, and the 2 out rod tubes are angled out and can handle at least a 7' rod. The rods slide into the PVC tubes, with the reels and butts extending out but under the foredeck so they're protected.
I need to come up with some way to hold the butts up to the underside of the foredeck. I was thinking of making short little bungees for each rod butt with the ends attached to the underside of the foredeck. I don't have any extra room to make a regular rod holder work once I slide the rod in the tube. Any ideas?
- Gert van Leest
Fiberglass advice
Earned my way thru college painting and repairing show cars, after every repair of body work, I would spray out the section with gloss black lacquer, u will see the ripples, kinda like the capts rattle can approach to finding imperfections
The technique is called tracing...
The spray can paint of choice is an automotive sandable lacquer primer. (Color is unimportant, but I prefer gray.)
Get a good brand, such as Krylon. Cheap brands usually have crappy spray nozzles and tend to splatter and dribble. You want a good atomization of the paint.
Hold the can about 12" to 24" away from the surface and just mist the paint on. The lacquer primer is almost dry as it hits the surface and has a very weak bond.
When you long board or block the surface, the high/low spots will be reveled by the removal of the primer from the high spots. Either continue sanding to reach the low spots, or build out the low spots with fairing compound as needed.
If you choose to build up the low spots, circle them lightly with a pencil, hand sand the primer trace away and add the fairing.
Repeat the overall process as needed. Once you've reached the degree of perfection you want, rinse the surface, dry, and shoot your final two coats of epoxy primer. A final light sanding with 320 grit and you're ready for top coat.
Thanks Capt. Pat.
"degree of perfection" - really?
If anybody is looking for an activity that gets your heart rate up, and later in the day, reveals all the arthritic problem spots in your shoulders and hands, its longboard sanding.
- TailhookTom
John:
When I longboarded my B31 -- I used bright green and orange (rotated the colors) until I only ended up with the initial 545 grey primer left on the boat. I'm not good at it, I don't have patience, and I hear you on the arthritis and cardio -- therefore, I needed neon to make it more entertaining and easier for a slug like me to get decent level of perfection.
Tom
Tom
Fiberglass repair
Yes on the post sanding , I would suggest to block sand with 150 and identify the voids / scratches ,etc, if u have used 545 , fill shallow imperfections with Awl fair, I have also filled them with a polyester filler by Evercoat,,goes off quick ,re prime, go thru the rattle can proceedure again block sand, if ok spray on the final coat of primer and sand out with 320 ,then follow suggested finish coating procedures, I use Awl craft because it is easily repairable and if u do get a run in a tight corner or wherever u can color sand it out, buff and your okay, always put on the 3 rd color coat , gives a greater build up that allows u to color sand or buff out in years to come, my theory
Fair, sand, tracing/prime, fair, sand, tracing/prime, etc. I have both limited understanding of materials and don't have a compressor/gun, so I make do with West Sys. Epoxy and fairing filler, rattle can primer, and Interlux single-part primer. Some progress:
Users browsing this forum: Google [Bot] and 356 guests
