I think ethanol got me
Having a '79 FBC with no problems thought I might be safe. Wrong! Tore down Starboard engine, one bent push rod, tore down port engine, one broken pushrod. Looks like no damage to pistons, cams, etc. Valve job, and new fuel tank. Talking to Alex W. about fiberglass tank. Getting quicker at getting heads off, 3 1/2 hours, but it is not fun. Hope everyone else is having a better day.
Jim
Jim
Sorry to tell you, you're never safe as long as ethanol is in your fuel. It WILL get you. Engines cool down and the closed valves get glued down. Start em up and bent pushrods. Had the same problem on my B-20. Had a season and a half thinking it was everything else. Rebuilt carburetor, fuel pump, electronic ignition, etc. As much as you may not like them, consider an aluminum tank replacement. If they ever go to E-15, you don't know what that might do to a new fiberglass tank. Mercruiser told me if they went to E-15, all bets were off on my new engine warranty. Replace all fuel lines and vent lines too. Ethanol eats the old hoses out on the inside. Ugh!
ethanol
Had the same problem. Decieded to go to diesel was the best option for me. I saved a piece of the old fuel take to show people. I went with a new aluminum fuel tank .25 thick and all new hoses. best of luck to you
Bill Mckinnon
Bill Mckinnon
Thanks everyone. Yes, the machine shop doing the heads said the stuff was really difficult to get off. They had never seen it before. Still looking at tank options, you may be right about the E15 issue with new fiberglass tanks. Is it safe to run the boat for a couple of weeks before new tank?
Tanks again,
Jim
Tanks again,
Jim
Users browsing this forum: No registered users and 14 guests
