My 454 Crusader's flame arrestors are gunked. Looks like general oiliness with some belt dust and deteriorated engine box insulation. I've been told more ways to clean them then I can count, they include:
*Dump 'em in a bucket with -Diesel -or -Mineral Spirits -or -Simple Green -or -Gumount -or -WD40
*Only use K&N special Flame Arrestor cleaner
*Spray aerosol break cleaner from the inside out
* don't scrub em -vs -scrub em with a firm or soft brush
* let 'em dry -vs -blow compressed air through 'em before they dry
... and the ever popular non answer- wouldn't you rather have diesels? That boat really should have diesels....
Gentlemen what's right?
Cleaning Flame Arrestors
- Capt.Frank
Stephan,
They are metal...no special element involved, so nothing more then a grease cutting solvent and something to dislodge the crude.
Gasoline, kerosine, diesel fuel, carb cleaner, brake cleaner, spray nine, 409, dish detergent all work just fine. It's what you have available.
The to get the crude out after it is loosened up from the solvent...again what you have available and how badly the crude is cruded up. Compressed air, Jet Spray from a water hose, a few good dunks and swishes in a bucket, get at it with elbow grease and a brush. Just make sure its dry before you reinstall and your golden.
Keep in mind if your using a Petroleum based product, you want to take care about fumes, and no matter what you are using, you will have petroleum residue running out...EPA don't take kindly to that.
Users browsing this forum: Bing [Bot], Google [Bot] and 171 guests
