Piling caps
Piling caps
Faithful - I've got 10 round pilings that hold up my dock across the back yard of my camp, rainge in diameter from about 8 to 10". I need to put flat plastic black round caps on them to slow down the rot. But.....after some google work, the damn things cost in the range of $13-18 each....now that's just plain ole hi way robbery....anyone got a source a little cheaper?
UV, po' ole retired guy
- Russ Pagels
I ran some of those same ideas by the Bride, like cut down plastic flower pots, etc....she sort of looks at those like putting aluminum foil on the inside of the windows in your double wide. One of our camp neighbors has the real sho' nuff black plastic flat piling caps (flat so you can put your beer can on them) and has vetoed half ass fixes. She's kinda like that, hi maintaince if you know what I mean.
Harry, What's your source?
Same problem, Vic, highfreakingway robbery and high maintenance women. Think I agree on this one though, nice stuff all round including a Bertram 31, so why cheap out at the end? I need about twenty of those little beasts in various sizes and have been putting it off. Since I will be working on Dreamsicle this summer, (got to finish the interior) sure would be nice to tidy up the place.
I guess I am just old school. Copper used to make the best ones, but unless you have some excess flashing lying around it would be even more expensive. Aluminum might work OK where you are since the water is pretty brackish. Cut a circle bigger than the piling , segment it and bend it over the piling and nail the tabs.
You guys are like democrats, enjoy spending someone else's money. Okay, okay, I'll buy the damn real ones....I notice they come in hlaf inch increments so I'll measure again this week to get it real, real pretty. I even got complaints last week that the Pedal Yacht was sorta dirty and I was falling down on my job as a Boat Slave.
I can't afford to be this rich.
UV, How bout polyester resin n a few layers of fabric, tint the resin, black, white or what ever color the brides eyes are....each piling would have a custom fit...BH
http://www.wigmanshardware.com/Mikey wrote:Harry, What's your source?
I just happened to be in there last week and saw the Piling Caps. I have for several years now intended to cut some SS rings and fabricate piling covers........in the end it probably would only cost me $50K to cover 6 pilings......just kidding guys.....LOL
Here's the scoop......A 10" dia cap is $10.99 and a 7" cap I paid $8.99.
So here ya go Vic.....you and Andre' drive over one morning.....to the tune of nearly $4 per gallon.....let me know when and I will meet you at that Swedish Restruant (ie McDonalds) and we will have lunch.....pick up the caps and head back home.
Or if you like I will go get them and UPS them to you......and anyone else for that matter. I may even be heading to Houston in a few weeks.....and could make a special delivery to Drusillas.
On another note.....the reason I was at Wigmans was to purchase a product called "Encore". I discovered it at the boat show this year. Encore is a product that when all mixed up is a water based polymer that is used to coat deck boards and delay decay. My deck at the river is getting pretty shabby. We will most likely be putting Encore on in a couple of weeds. I fell in love with the idea. I will take pics before and after.....I know several of you guys have docks and I thought this may be of interest to ya.
http://www.mercoboatdocks.com/our-produ ... lack/round
Try these people. Might be a couple of dollars cheaper.
I will give you another alternative, which my neighbor did after I gave him the idea. He used 5200 but basically take a tube of black silocone and spread it over the top of the piling . Home Cheapo stuff should work. Depending on the size of the piling you might be able to do two pilings to a tube. He did his about 11 years ago. They look like the could be recoated again.
Tony, thanks again. They sent a catalog with the caps and looks like a real fun family operation (all they make are dock parts, etc) with no-nonsense pricing. I particularly like their seaplane lift for a float plane. Reminds me of years ago at Port Eads when a buddy of mine who had a jazzed-up Cessna 185 on floats had Buzzy Scarabin, the harbormaster, build him a seaplane ramp so he could run the 185 up on it next to his houseboat which was moored next to Andre's. Seaplane floats leak like Swiss cheese and the plane might sink overnight, plus several hundred pounds of water in the floats makes the plane resemble a large brick in the flying dept. The 185 had amphib. floats with wheels you could lower to taxi it on land....so anyway, Buzzy, his late brother Wayne, and some other Einstiens of Port Eads designed and built a heavy duty seaplane ramp at untold, but certainly staggering cost. It was the envy of all until the plane owner tried to taxi the 185 up the ramp onto the platform....hmmm, the ramp was a little steep and the po' ole 185 didn't have 4WD....the tail dipped into the muddy water and the red & white flying machine lurched to a stop halfway up the ramp....took a dozen drunks to push it back into the water. The ill-fated seaplane ramp became first a great BBQ spot, then the goats took it over and turned it into a Goat-a-minium. Never learned how the warranty worked out, but knowing Buzzy & The Port Eads Way, I suspect my buddy ended up paying full price twice.
Anyway, Merco seems to be a good place of dock stuff.
Users browsing this forum: Google [Bot] and 99 guests
